How to edit data
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
HenkHavelaar
Domoticz version: V4.9700
How to edit data
Post by HenkHavelaar » Friday 14 September 2018 16:38
Version:4.9700
Platform: Windows 10
Hardware: RFXcom USB tranceiver, Open Zwave USB Aeotec, Davis Vantage Weather station
I'm using a RFX powermeter but sometimes there are strange values measured or recorded (see attachement), were can I find the database with the measured values and how can I edit these values?
KWh use.jpg (54.19 KiB) Viewed 75 times
Domoticz on Synology NAS and Windows 10
Interfaces: zWave and RFXcom
Locations: Netherlands and Portugal
zicht
Domoticz version: 3.8xxx
Re: How to edit data
Post by zicht » Friday 14 September 2018 21:08
Database is the file domoticz.db in the domoticz dir (see normal programs dir, in windows)
Sql edit is possible with several tools, the tables are very logical. I would not recommend to alter directly, but if you do make a backup. All sensors and settings are stored there so if you corrupt something you can start from scratch.
Rpi & Win x64. Using : cam's,Nest,RFXCom,Kaku,LaCrosse,RFY,IsAlive,Dummy,Wether Underground, standard Lua, Curl on windows,Domoticz Android App & Tasker,
"The only source of knowledge is experience (A.Einstein)"
tun0
Post by tun0 » Friday 14 September 2018 21:15
If you want to delete a datapoint rather than alter it, just click it while holding shift. Otherwise you'll have to dive into the database indeed.
Users browsing this forum: No registered users and 6 guests
