Custom Sensor: Leaf Wetness and MQTT
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
acaonweb
Target OS: Raspberry Pi
Post by acaonweb » Friday 14 September 2018 15:46
Domoticz Version 4.9700
Raspberry PI 3 Raspbian Jessie
Hardware: Xiaomi Gateway + Xiaomi Button + Sono Basic Tasmota firmware
Hi, i need to understand this behavior.
I've have created two custom sensors (Dummy): the first is a Temperature sensor (IDX:140) and the second is a Leaf Wetness sensor (IDX:141)
now if in the terminal I type
mosquitto_pub -h localhost -m '{ "idx" : 140, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
i can see the new value in the sensor Temperature
but if i type
mosquitto_pub -h localhost -m '{ "idx" : 141, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
nothing happens.
I've tried a General Custom Sensor, a pressure sensors and everything works fine...
I think it's a bug...
Any suggestion?
tun0
Re: Custom Sensor: Leaf Wetness and MQTT
Post by tun0 » Friday 14 September 2018 21:19
Try passing the value through nvalue (25) instead of svalue ("25.0")?
acaonweb
Post by acaonweb » Friday 14 September 2018 22:05
The format is the same sent by easyesp firmware on Wemos D1, so I think it have to be the right syntax...
Every other Custom Dummy Sensor works fine.
tun0
Post by tun0 » Friday 14 September 2018 22:29
No errors in the domoticz log either?
acaonweb
Post by acaonweb » Saturday 15 September 2018 19:54
no error, in the log mitt is sent correctly
