Custom Sensor: Leaf Wetness and MQTT
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
acaonweb
Target OS: Raspberry Pi
Post by acaonweb » Friday 14 September 2018 15:46
Domoticz Version 4.9700
Raspberry PI 3 Raspbian Jessie
Hardware: Xiaomi Gateway + Xiaomi Button + Sono Basic Tasmota firmware
Hi, i need to understand this behavior.
I've have created two custom sensors (Dummy): the first is a Temperature sensor (IDX:140) and the second is a Leaf Wetness sensor (IDX:141)
now if in the terminal I type
mosquitto_pub -h localhost -m '{ "idx" : 140, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
i can see the new value in the sensor Temperature
but if i type
mosquitto_pub -h localhost -m '{ "idx" : 141, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
nothing happens.
I've tried a General Custom Sensor, a pressure sensors and everything works fine...
I think it's a bug...
Any suggestion?
tun0
Re: Custom Sensor: Leaf Wetness and MQTT
Post by tun0 » Friday 14 September 2018 21:19
Try passing the value through nvalue (25) instead of svalue ("25.0")?
acaonweb
Post by acaonweb » Friday 14 September 2018 22:05
The format is the same sent by easyesp firmware on Wemos D1, so I think it have to be the right syntax...
Every other Custom Dummy Sensor works fine.
tun0
Post by tun0 » Friday 14 September 2018 22:29
No errors in the domoticz log either?
acaonweb
Post by acaonweb » Saturday 15 September 2018 19:54
no error, in the log mitt is sent correctly
chaimeichini
Post by chaimeichini » Wednesday 07 November 2018 12:20
The wireless leaf wetness sensor detects the presence and quantity of water on its surface through the measurement of constant dialettrica, that in the case of water has a significantly higher value than to that of air, and the variation between two electrodes present in the sensor .
There are also sensors that according to the level of wetness, detect a change in the electrical resistance between the elements of a grid that make up the sensor itself.inro.in/showbox inro.in/mobdro inro.in/tutuapp/
Domoticz Version: V4.9700
Platform: RaspberryPi 3
oxedgar
Post by oxedgar » Wednesday 07 November 2018 22:30
but if i type
nothing happens.
Any suggestion?
Hello, i think u need to send mqtt frame with the value on the nvalue and not in the svalue like this:
mosquitto_pub -h localhost -m '{ "idx" : 141, "nvalue" : 25.00, "svalue" : "0" }' -t 'domoticz/in'
in my case, i use this to send values with battery level and radio level :
  String rqt = "{ \"idx\":" + String(idx) + ",\"nvalue\":" + String(value) + ",\"svalue\":\"0\" "+ ",\"RSSI\":" + String(RssIdomo) + ",\"Battery\":" + String(Batlevel) + "}";
in my case this working fine...
have a nice day...
acaonweb
Post by acaonweb » Friday 16 November 2018 20:25
but with leaf sensor?
