RFXCOM Noisy data
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
qqlapraline
Target OS: Raspberry Pi
RFXCOM Noisy data
Post by qqlapraline » Friday 14 September 2018 11:48
Version: 4.9999
Platform: Raspberry PI / Raspbian 4.14.69+
Plugin/Hardware: RFXCom / Firmware 1025
Description:
I've been having a RFXCom for the past 3 years. Unfortunately, since about 6 months, I get noisy data (see below on zoomed charts).
chart (1).png (81.26 KiB) Viewed 319 times
The attachment chart (1).png is no longer available
Most received values are OK but some of them are totally wrong.
I have checked many things (USB ports, rfxcom position, various updates, ...) with no success.
I have many sensors running through RFXCom (about 12).
If anybody has an idea, I would be gratefull.
Regards,
QQ.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Various mysensors devices (Temp, Hygro, ...)
zicht
Domoticz version: 3.8xxx
Re: RFXCOM Noisy data
Post by zicht » Friday 14 September 2018 21:02
Just to not forget the obious, battery levels are ok or powersupply checked. Mine are behaving strange when batt are getting low.
Is it just one sensor ? or more ?
Has there anything been changed ?
I would look into or a broken sensor, or in background noise of some kind of transmitter (neighbours ?)
Rpi & Win x64. Using : cam's,Nest,RFXCom,Kaku,LaCrosse,RFY,IsAlive,Dummy,Wether Underground, standard Lua, Curl on windows,Domoticz Android App & Tasker,
"The only source of knowledge is experience (A.Einstein)"
qqlapraline
Post by qqlapraline » Saturday 15 September 2018 9:25
Thanks for you reply.
It's all the sensors (around 27 devices). Some of them have low battery level but most of them are good.
QQ
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
EddyG
Domoticz version: 4.9999
Post by EddyG » Saturday 15 September 2018 9:51
In the RFX manual there is a table of devicetypes that are not getting along with each other, did you check those settings.
I once had a time that Domoticz screwup those settings, then I had to revert back to RFXmngr to get them right again.
What firmware are you using in RFX?
Regards,
Eddy
qqlapraline
Post by qqlapraline » Saturday 15 September 2018 12:53
Yep, I did.
The default protocols are activated.
But you may be right. I will try to have a look at it when possible.
Nonetheless, the settings have not changed for the past months.
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
qqlapraline
Post by qqlapraline » Sunday 23 September 2018 22:10
I have checked again my installation.
It appears that a former device was remaining in the list after its hardware uninstallation.
It was linked to the same USB port... This was the cause of the noise.
After 3 days of fix, no more noise.
Sorry for this, guys ;)
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
chaimeichini
Post by chaimeichini » Tuesday 06 November 2018 12:32
My server and RFXTRXe are in the attic on 1 side of the house (facing the garden, since most of my equipment I use is there), but now I want to use a door-sensor on the first floor (4 ceilings between them) on the other side of the house. :roll:
I can not get a signal there, not even with a new antenna, but I do have network (CAT5e) there connected.
So how to achieve this? A 433 to lan to 433 converter of somesorts?Rightmove Kijiji Quizlet
Last edited by chaimeichini on Wednesday 07 November 2018 21:20, edited 1 time in total.
b_weijenberg
Post by b_weijenberg » Tuesday 06 November 2018 12:52
Install ser2net on a Raspberry PI to connect the RFXtrx over LAN:
viewtopic.php?f=28&t=192&p=65097
RFXtrx433, RFXtrx433E, RFXtrx433XL
