Problem on/off action for System Alive Checker (Ping)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
axelct
Target OS: Raspberry Pi
Post by axelct » Thursday 13 September 2018 15:51
I'm very happy to use domoticz, it's great!!
My installation is:
Version: 4.9700
Platform: Raspberry Pi
And I've have the following problem:
I've used the System Alive Checker to ping a server and it works perfect (the server status is reported correctly).
I've defined an off and on action with script, but always, when I trigger the on/off action I get the following message: "Error sending switch command, check device/hardware !"
The scripts have no error, I've tried to run manually by command line and both script works, I've defined the same script as on/off action in a switch device and works with no problem.
Have I missing anything or could be a bug?
Thanks,
Alessandro
axelct
Re: Problem on/off action for System Alive Checker (Ping)
Post by axelct » Thursday 13 September 2018 15:57
Uhm, I've got by myself... sorry, looking at the log I've got this message:
Error: Pinger: This is a read-only sensor!
Seems to be very clear, I think no way out... so do I need two devices? One for Systema live chech and the other as switch device to perform on/off action?
Alex
HansieNL
Post by HansieNL » Thursday 13 September 2018 17:01
I made 3 dummy switches and use a LUA script to ping the devices and they have off scripts. Maybe you can use this LUA script:
commandArray={}
-- Debug mode (display of messages)
debug=true
-- Prefix for log outputs
prefixe="(Ping) "
-- Table of devices to ping
-- Key = ip address to ping
-- Value = virtual device to switch
local ping={}
ping['192.168.2.22']='Desktop PC'
ping['192.168.2.6']='Mede8er'
ping['192.168.2.55']='Notebook PC'
--For each entry in the table
for ip, switch in pairs(ping) do
 --Ping ! : -c1 = one ping , -w1 one second waiting time
 ping_success=os.execute('ping -c1 -w1 '..ip)
 --If the ping answered
 if ping_success then
   if(debug==true)then
    print(prefixe.. switch.. " online")
   --If the switch was off it is turned on
   if(otherdevices[switch]=='Off') then
      commandArray['UpdateDevice'] = otherdevices_idx[switch]..'|1|0'
 --If no answer
   if(debug==true)then
    print(prefixe.. switch.. " offline")
   --If the switch was on it is turned off
   if(otherdevices[switch]=='On') then
      commandArray['UpdateDevice'] = otherdevices_idx[switch]..'|0|0'
Blah blah blah
Users browsing this forum: waaren and 5 guests
