File not found when installing on Ubuntu
BentCold
Target OS: Raspberry Pi
Post by BentCold » Thursday 13 September 2018 13:03
I'm trying to install a Proof Of Concept Domoticz server on a virtual LightUbuntu machine for my Home Automation project. (Will be on a Raspberry Pi in Production). To prove to myself that Domoticz can do all it says - and I can figure out how to :-)
But when I install using the curl macro I get a 404 File not found.
Do I need to add some repository / path / ... ?
I'm neither a programmer nor a Linux expert - so maybe its elementary :-)
Bent Cold
hscholing
Re: File not found when installing on Ubuntu
Post by hscholing » Tuesday 25 September 2018 21:07
Same problem here.. cannot install now
gerardsoraya
Domoticz version: v3.8763
Post by gerardsoraya » Tuesday 25 September 2018 21:49
BentCold wrote:I'm trying to install a Proof Of Concept Domoticz server on a virtual LightUbuntu machine for my Home Automation project. (Will be on a Raspberry Pi in Production). To prove to myself that Domoticz can do all it says - and I can figure out how to :-)
Bent Cold
I have been struggeling with that problem for months and nobody on this forum. I have running it now for 2 days without problems. Ive done a clean install of Ubuntu and than ive done apt-get update and apt-get upgrade. After that i have done the installation the hard way (compiling from source). This was the solution for me. I have even contacted my provider of they had blocked anything haha. I also bought an other desktop and that was not the solution. Let me know if you want information and if it is solved.
Verstuurd vanaf mijn SM-G965F met Tapatalk
ubuntu
rflink 433 mhz
rflink 868 mhz
p1 smart meter cable
toon thermostaat
otgw
pretty noob but whit google i've done a lot
