group.state not on / mixed
terrorsource
Target OS: Raspberry Pi
Post by terrorsource » Thursday 13 September 2018 10:51
I'm trying to make a dzvents script based on a group of lights.
I want to switch "Slapen" on when all lights are off between nighttime.
Is it possible to get the status "Mixed" of a group?
I now have a script based on "group.state == 'Off'" but "On" should not work because not all lights are on at once.
Can i set "group.state == 'Mixed" ? It is not stated in the wiki.
Re: group.state not on / mixed
Post by waaren » Thursday 13 September 2018 11:07
Yes,
    on         = { devices     = { "triggerDevice" }},   -- Change for your triggerDevice
    logging    = { level       =   domoticz.LOG_DEBUG,
                   marker      =   "Check Group state"        },
    execute = function(dz)
        myGroup = dz.groups("All active devices")  -- Change for your group
        if myGroup.state == "Mixed" then
            dz.log("state of group " .. myGroup.name .. " ===>> " .. myGroup.state,dz.LOG_DEBUG)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
terrorsource
Post by terrorsource » Thursday 13 September 2018 13:18
Yes,
I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
      groups = { 'AlleLampenHuis' }
        myGroup = dz.groups("AlleLampenHuis")  -- Change for your group
        if myGroup.state == "Mixed" and domoticz.devices("Thuis").state == "Off" then
        --    domoticz.devices("Slapen").switchOff().checkFirst()
            domoticz.notify("State=MIXED","State=MIXED.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
        elseif  myGroup.state == "Off" and domoticz.devices("Thuis").state == "Off" then
        --    domoticz.devices("Slapen").switchOn().checkFirst()
            domoticz.notify("State=OFF","State=OFF.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
        elseif  myGroup.state == "On" and domoticz.devices("Thuis").state == "Off" then
            domoticz.notify("State=ON","State=ON.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
Post by waaren » Thursday 13 September 2018 17:31
terrorsource wrote:
Yes,
Try change all "dz" to "domoticz" or vice versa.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
terrorsource
Post by terrorsource » Thursday 13 September 2018 20:25
terrorsource wrote:
Yes,
Still not working. I've even cleaned up the script but it is not sending messages. Looks like it's never triggered.
Now have only 1 switch in the group, a dummy switch. when i toggle it nothing happens.
    execute = function(domoticz, group)
        myGroup = domoticz.groups("AlleLampenHuis")
        elseif  myGroup.state == "Off" then
        elseif  myGroup.state == "On" then
Post by waaren » Thursday 13 September 2018 21:21
terrorsource wrote: I've now created this, but it is not sending a message via Prowl when the status of the Group changes.
The script in its current form will only execute when the group is switched On or Off. State changes of any device in the group will not trigger it.
domoticz simply does not create a group level event for it and dzVents is therefore not aware anything changed on the grouplevel.
If you want to have the script triggered on any groupdevice change you will have to add these devices in the "on = devices" section
 on         = { devices     = { "groupdevice1, groupdevice2 , ... groupdevice99" }},
what might help is that these devicenames can be entered in a wildcard form e.g. group*
terrorsource
Post by terrorsource » Friday 14 September 2018 9:28
The last script is just for test purposes only.
Want to have it send a message when the group has changed (ON/OFF/Mixed).
From there on i can switch "Sleeping" on and create an alarm for motion and doors.
Post by waaren » Saturday 15 September 2018 21:48
Maybe this other approach can help you achieving what you want. It will notify you within a minute after a group state change happens by a device in that group or imediate when the group itself was changed manual of via a command.
When executed the first time it will also send 1 notification
local groupName = "AlleLampenHuis"
        groups        = { groupName },
        timer         = { "every minute" },
        httpResponses = { "getSceneState" }},
    logging =   {
                    level           = domoticz.LOG_INFO,
                    marker          = "getSceneState"
     data    =   {  state                 = { initial = "" }},
    execute = function(dz, item)
        local myGroup = dz.groups(groupName)
        local function triggerJSON()
            local urlString = dz.settings['Domoticz url'] ..  "/json.htm?type=scenes"
            dz.openURL({    url = urlString,
                            method = "GET",
                            callback = "getSceneState" })
        local function getState(groupName)
            local state = "No state found for " .. groupName
            if item.json.result ~= nil then
                rt = item.json.result
                dz.log("No values found",dz.LOG_DEBUG )
                return
             for i=1,#rt do                                                  -- Loop through the result
                dz.log(     "Checking group " .. rt[i].idx .. " ===>> " .. rt[i].Name ,dz.LOG_DEBUG)
                if rt[i].Name == groupName then
                   return rt[i].Status
            return state
        if item.isHTTPResponse then
            myGroup.state = getState(groupName)
            if myGroup.state ~= dz.data.state then
                dz.data.state = myGroup.state
                dz.log("State changed to " .. myGroup.state, dz.LOG_FORCE)
                dz.notify("State=" .. myGroup.state ,"State=" .. myGroup.state, dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
                dz.log("State of : " .. myGroup.name .. " is still " .. myGroup.state, dz.LOG_DEBUG)
            triggerJSON()
terrorsource
Post by terrorsource » Monday 24 September 2018 11:36
Thanks for the script. i've extended it a bit further.
This is the result:
        timer         = { "every minute between nighttime and 05:00", "at 05:01" },
    logging =   {
                            method = "GET",
                return
                   return rt[i].Status
            return state
            if domoticz.time.matchesRule("at 05:01") then
				dz.devices("Slapen").switchOff().checkFirst()
				dz.notify("Slaapstand=OFF","Slaapstand is uitgezet.", dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
            elseif myGroup.state ~= dz.data.state then
				if dz.data.state == "Off" and dz.devices("Thuis").state == "On" then
					dz.devices("Slapen").switchOn().checkFirst()
					dz.notify("Slaapstand=ON","Slaapstand is aangezet.", dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PROWL)
				elseif dz.data.state == "On" and dz.devices("Thuis").state == "On" then
				elseif dz.data.state == "Mixed" and dz.devices("Thuis").state == "On" then
            elseif
                dz.log("Status van : " .. myGroup.name .. " is nog steeds: " .. myGroup.state, dz.LOG_DEBUG)
            triggerJSON()
Users browsing this forum: HenMus, sexyboy, Skippiemanz and 6 guests
