Accessing the room plans.
brunonar
Post by brunonar » Wednesday 12 September 2018 22:39
How do I get the floor plan and room plan associated with my python plugin's Device?
I need it for context commands that I'm trying to create. I'd like to do something like "turn off all lights of Mary's room" or "Turn on John's TV".
Thanks.
brunonar
Re: Accessing the room plans.
Post by brunonar » Monday 08 October 2018 22:56
I tried everything but I think that it's not a feature currently supported.
What I did temporarily to solve the problem was use the device's description field as the device location, so the plugin could access it. But this is very bad.
Target OS: Raspberry Pi
Post by waaren » Monday 08 October 2018 23:03
http://domoticzIP:domoticzPort/json.htm?type=plans&order=name&used=true gives you all the rooms and http://domoticzIP:domoticzPort/json.htm?type=command&param=getplandevices&idx=<planID> gives you all devices in the roomplan <planID>
Does that not help you ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
brunonar
Post by brunonar » Monday 08 October 2018 23:59
Thank you for the answer, Waaren!
My plugin would have to ask the user's username and password for that, wouldn't it?
mvzut
Post by mvzut » Tuesday 09 October 2018 7:34
Not if you use 127.0.0.1 and add this to the Local Networks list (under settings).
Raspberry Pi 3 - RFXtrx433 - Aeon Z-Stick gen5 - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - Xiaomi Gateway - Sonos - IP cameras - Wall mounted tablet + Imperihome - MANY switches/sensors
brunonar
Post by brunonar » Tuesday 09 October 2018 8:07
Thank you very much! I'll try it!
