brother printer support phone number and its support phone number
albert9211
Post by albert9211 » Wednesday 12 September 2018 22:20
Steps To Overcome Brother Printer Phone Number Common Issues
STEPS TO OVERCOME BROTHER PRINTER COMMON ISSUES
Are you having issues with your Brother Printer Phone Number ? If so then you’re on the right page. In this blog, we will guide you on how to settle the common issues related to the brother printer. However, you can also opt to dial our Brother Printer Phone Number and connect with our experts for the quick the settlement of the printer issues.
Brother Printer Common Issues
No Printout
In case if your printer failed to take the print command then follow the below-mentioned suggestion very carefully
Make sure the Brother Printer Phone Number is plugged in and the power source is turned on.
Check that the drum unit and toner cartridges are correctly installed.
Make sure that interface cable on both PC and your machine is properly connected.
Make sure that you have installed the correct version of the printer driver on your system.
And at last, make sure that your machine is online.
Printer LCD shows no paper
In this case, verify the following suggestions.
If there is no paper in the paper tray, load a new stack of paper.
Makes sure to discard the poor quality paper from the paper stack
Align the paper correctly before loading the stack into the paper tray.
Disable manual feed mode in the printer driver.
Paper Jam
To clear the paper jam from the printer, follow the underneath steps carefully.
Pull out the paper tray from the printer.
Once you find the paper in the roller unit, slowly pull out the jammed paper.
Installed the paper tray back into the machine.
Press Color Start or Mono Start to resume printing.
Printing failed over a wired network
If you are encountering a network problem, make sure that your machine is powered on. You need to go through the current network setting. Change the LAN cable if it’s quality not up to the mark. If the issue still persists, make sure to connect your printer to the different port on your hub.
Hope the above-mentioned method will help you to eliminate the printer issues. For more detail and help on the issues, connect with Brother Printer Tech Support executive at any point in time.
http://brothercustomersupport.com/blog/ ... on-issues/
