Problem with 433 Mhz magnetic door contact Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
petercal
Target OS: Raspberry Pi
Post by petercal » Wednesday 12 September 2018 17:29
Version: 4.9700
Platform: Raspberry Pi
Plugin/Hardware:
Description:
Hi, I'm quite new to Domoticz.
I have a 433 Mhz magnetic door contact. It has 2 states CLOSE when magnet is close to reed relay and OPEN when magnet is away from reed relay.
I want to add the 433 Mhz magnetic door contact as a device, and be able to detect the OPEN/CLOSE states.
When i check the device with debug in RFLinkLoader.exe program i see
20;0A;EV1527;ID=0019f0;SWITCH=0a;CMD=ON; OPEN state (SWITCH=0a)
20;0B;EV1527;ID=0019f0;SWITCH=0e;CMD=ON; CLOSE state (SWITCH=0e)
When i register the device in Domoticz i get 2 devices with both ON state active
2018-09-12 16:54:45.569 (RFLink) Light/Switch (Unknown) OPEN state
2018-09-12 16:55:10.246 (RFLink) Light/Switch (Unknown) CLOSE state
What can i do to get it working as a single open/close contact ?
Thanks,
Peter
Last edited by petercal on Wednesday 12 September 2018 22:24, edited 2 times in total.
ben53252642
Re: Problem with 433 Mhz magnetic door contact
Post by ben53252642 » Wednesday 12 September 2018 17:33
Is this how the two devices are functioning?
Device 1, door closed = send on signal to domoticz device
Device 2, door open = send on signal to domoticz device?
If so, the solution is easy:
1) Create a virtual on / off switch in Domoticz
2) Use a Lua script to set that device to the correct on / off state depending on which of your magnetic door contact devices updates.
Sounds like it's created a seperate device for each state (open and closed)?
If you need help with a sample script I can supply one.
petercal
Post by petercal » Wednesday 12 September 2018 18:27
You're right, thats how it work.
I'll try your solution, and an example script would be much apreciated :)
thank,
Peter
ben53252642
Post by ben53252642 » Wednesday 12 September 2018 18:45
Paste into Domoticz events as a Lua device script (very important to change type from "All" to "Device")
Change as needed, it should work.
if (devicechanged['DEVICENAME1'] == 'On') then
commandArray['VIRTUALSWITCH'] = 'On'
elseif (devicechanged['DEVICENAME2'] == 'On') then
commandArray['VIRTUALSWITCH'] = 'Off'
petercal
Post by petercal » Wednesday 12 September 2018 18:48
I'll try this
WORKS PERFECT :D
Thank you very much.
Peter
Users browsing this forum: No registered users and 4 guests
