Energy meter dual tariff
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
diogoc
Post by diogoc » Wednesday 12 September 2018 13:25
I'm using mysensors to visualize the consumption of my energy meter in domoticz.
The meter have two tariffs, so I like to have a single device in domoticz that shows the consumption of each tariff.
It is possible to do that?
BugsBob
Re: Energy meter dual tariff
Post by BugsBob » Thursday 20 September 2018 15:07
"It is possible to do that?"
Hmm, was wondering about the same thing. Hope someone would help with this.
jurgen
Domoticz version: stable
Post by jurgen » Tuesday 25 September 2018 9:49
go to settings -> meters and counters
edit t1 and r2
diogoc
Post by diogoc » Tuesday 25 September 2018 17:29
edit t1 and r2
??? How this help with the problem?
jurgen
Post by jurgen » Wednesday 26 September 2018 19:08
edit t1 and r2
I use a P1 smart meter with dual tarif, in the meters and counters section you can edit the cost per tarif. I don't know for sure if this also works when using mysensors.
diogoc
Post by diogoc » Wednesday 26 September 2018 23:36
Ah ok.
I did not need the cost. It is enough to have consumption in kWh of each tarif
miroslavpetrov
Target OS: Raspberry Pi
Post by miroslavpetrov » Thursday 27 September 2018 11:32
I am also interested in this topic. I am using Eastron SDM630 (with this python plugin https://github.com/MFxMF/SDM630-Modbus). Any suggestion on how to use two tarrifs and also how to set the time periods for each tarrif?
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Gravityz
Domoticz version: V3.8637
Post by Gravityz » Monday 01 October 2018 19:51
found the solution so sharing it with you.
you can comment out the meters you do not need
i only use low and high tarif
https://domoticz.com/forum/viewtopic.php?t=22177
diogoc
Post by diogoc » Tuesday 02 October 2018 1:16
I will try. Thank you.
Users browsing this forum: vchecco and 0 guests
