activate a scene from a remote computer CL
ocupmoc
Post by ocupmoc » Tuesday 11 September 2018 20:31
I have a Domoticz server running on Windows 10 with an MQTT broker for my Sonoff Tasmota switches.
Now I would like to activate a scene from a remote windows computer using command line/batch file.
Anybody any idea how to do this?
Cheers,
Arco
SweetPants
Domoticz version: V4.10069
Re: activate a scene from a remote computer CL
Post by SweetPants » Tuesday 11 September 2018 20:38
curl -s 'http://<server>:<port>/json.htm?type=command&param=switchscene&idx=&switchcmd="<On or Off>"' where idx is the ID of the scene.
See: https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
ocupmoc
Post by ocupmoc » Wednesday 12 September 2018 8:14
@SweetPants, cURL and JSON don't mix in that way but you've given me some more leads to explore, many thanks!
SweetPants
Post by SweetPants » Wednesday 12 September 2018 8:16
Why don't they mix this way? It works fine if you follow the wiki. You have to install curl for Windows though.
Target OS: Raspberry Pi
Post by waaren » Wednesday 12 September 2018 8:56
.. cURL and JSON don't mix in that way ..
curl does not like the ? and & so they need to be escaped or put the whole http string between double quotes.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
ocupmoc
Post by ocupmoc » Wednesday 12 September 2018 10:00
I've been reading that POST would need to be used but the double quotes work wonders, many thanks lads!
alanlsmith
Domoticz version: 4.9701
Post by alanlsmith » Tuesday 18 September 2018 11:05
A bit late but this could be used as an alternative:
commandArray[#commandArray+1] = {['OpenURL']='http://<domoticzIP>:<port>/json.htm?type=command&param=switchscene&idx=<sceneidx>&switchcmd=On'}
Or you could use one of these which will update the status of a device without triggering any script that is associated with that device:
commandArray[#commandArray+1] = {['UpdateDevice'] = '<deviceidx>|1|1'}
Will switch device on
commandArray[#commandArray+1] = {['UpdateDevice'] = '<deviceidx>|0|0'}
Will switch device off (not for scenes as they can only be switched on this way)
Edit:Just realised I didn't read the original post properly and the examples that I have given are for use in a lua script, not on a command line. Still they could be useful for someone.
FURTHER EDIT: These methods only change the status of a device and not actually trigger the device's action, I have only used them for dummy devices so didn't realise that this was the case until I did some proper testing.
Domoticz v4.9701 beta, Ubuntu 18.04 on Intel NUC i3, 8Gb ram, 70Gb drive, RFXtrx433, z-wave and a bit of Broadlink/Android
