plugin Zigate (USB+WiFi) - 2.4.0 Topic is solved
pipiche
Target OS: Raspberry Pi
Post by pipiche » Saturday 08 September 2018 9:45
We are keen to release this version off the Zigate Plugin, which include a set of update, enhacement and bugfixing.
- Configuration file to enable further configuration parameters
- New data capture from the zigate hardware. It involved also on the fly lenght and checksum validation, in order to ensure proper data transmitted to the plugin feature.
- Reporting device signal quality to Domoticz through RSSI.
- Reporting in the log at plugin start, the Zigate firmware version. We recommend using 03.0d
- Reporting in the log at plugin start and if the firmware version is greater than 03.0b
- We have onboarded a number of new devices ( Xcube Aqara, TRADFRI LED LED1624G9, ...) all of them are now documented in a file name : Compatible-Hardware.md . Feel free to let us know if you are using a device not listed there and working properly.
- Implementation of polling of Profalux shutter state, in order to update Domoticz devices in case of direct radio-command
- a number of bug fixes.
Please make sure to do a restart of the domoticz system in order that all changes are taken into account.
Please feel free to report issue through github: https://github.com/sasu-drooz/Domoticz-Zigate/issues
And if you have any questions, problem please use first the Domoticz forum.
- French channel : https://easydomoticz.com/forum/viewtopic.php?f=8&t=7099
- English channel : https://www.domoticz.com/forum/
If you want to contribue , please let us know , we are looking for help in various areas:
- certifying new ZigBee devices
- improving the plugin
- increasing the level of documentation for end user
Last edited by pipiche on Saturday 08 September 2018 11:22, edited 1 time in total.
LouiS22
Re: plugin Zigate (USB+WiFi) - 2.4.0
Post by LouiS22 » Saturday 08 September 2018 11:03
2018-09-08 11:03:00.120 Error: (zigate) ----> Line 678 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2018-09-08 11:03:00.120 Error: (zigate) ----> Line 147 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2018-09-08 11:03:00.120 Error: (zigate) 'onMessage' failed 'NameError':'name 'ReqRcv' is not defined'.
Any ideas?
pipiche
Post by pipiche » Saturday 08 September 2018 11:04
Which branch are you ?
Python version you are using ?
Last edited by pipiche on Saturday 08 September 2018 11:07, edited 1 time in total.
LouiS22
Post by LouiS22 » Saturday 08 September 2018 11:06
On Domoticz? Latest beta (4.9992).
pipiche
Post by pipiche » Saturday 08 September 2018 11:08
What about the Zigate plugin ? is that the Master ?
The variable is define is line 140 of the code !
LouiS22
Post by LouiS22 » Saturday 08 September 2018 11:11
Yes, installed it via github, as description provided. Python version is 3.5.3, if that counts.
Did a restart.
2018-09-08 11:07:50.821 Error: (zigate) 'onStart' failed 'FileNotFoundError'.
2018-09-08 11:07:50.821 Error: (zigate) ----> Line 666 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2018-09-08 11:07:50.821 Error: (zigate) ----> Line 78 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2018-09-08 11:07:51.225 Error: (zigate) 'onMessage' failed 'NameError':'name 'ReqRcv' is not defined'.
LouiS22
Post by LouiS22 » Saturday 08 September 2018 11:20
Ok, I sorted out. Removed the whole folder, restarted Domoticz, pulled from git, restarted again. Seems ok now, at least no messages in error log.
2018-09-08 11:18:46.647 Status: (Zigate) Started.
2018-09-08 11:18:47.003 Status: (Zigate) Entering work loop.
2018-09-08 11:18:47.004 Status: (Zigate) Initialized version 2.4.0, author 'zaraki673 pipiche38'
2018-09-08 11:18:47.013 Status: (Zigate) Zigate enter in discover mode for 254 Secs
2018-09-08 11:18:47.139 Status: (Zigate) Major Version Num: 0001
2018-09-08 11:18:47.139 Status: (Zigate) Installer Version Number: 030d
pipiche
Post by pipiche » Saturday 08 September 2018 11:24
Thanks a lot , I have updated the initial post in order to recommand a restart of Domoticz, as indeed we have also done few changes in the plugin headers ;-)
@LouiS22 thanks for finding out the solution
pipiche
Post by pipiche » Wednesday 12 September 2018 22:02
lazara007
Post by lazara007 » Wednesday 19 September 2018 16:57
It worked, error messages gone. thanks.
