Read out S0PCM-05
Melissen
Read out S0PCM-05
Post by Melissen » Thursday 30 August 2018 19:39
Just bought an S0PCM-05 meter at SmartMeterDashboard.
This device works 'great', but the PowerConsumption is not really spot on, more an average consumption instead of an actual consumption.
So I want to read out the values of the different meters. Or all meters at once, just like it's possible in Putty (cat /dev/ttyACM0).
So I can see how many pulses are counted in the last 10 seconds.
Then I write these numbers in different user-variables, so I can use the pulses of the last 30 seconds to make the actual-Power-consumption (watts)
Do I use something like: otherdevices_svalues[ ' .... '] to get these values?
Don't know where to start in this 'project'.
For now I use the devices that Domoticz makes when I create in HARDWARE the S0 METER USB-counter, but I want to make a counter like my watermeter, which directly responds when the water is used (bij counting a liter at a time) and my waterflowmeter (uses data from watermeter) and shows the use of water in liters/min. (also spot-on)
Hope someone can help me with pulling out the data in 'workable values'.....
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
Melissen
Re: Read out S0PCM-05
Post by Melissen » Thursday 30 August 2018 19:50
Every pulse is 0,5 watt... so if there are 8 pulses in the last 10 seconds. 4 watts are used in 10 seconds, means 24watts in one minute and 1440watts in one hour...
Because 10 second time frame isn't very accurate, I want to use a time frame of 30 seconds (of maybe longer). Or maybe one minute (I can use LUA TIME).
With 30 seconds time frame I get for example 7 , 8, 7 pulses... so 22 pulses in 30 seconds.
After the next 10 seconds (6 pulses are shown), I use 8 , 7 and 6 pulses...so 21 pulses in 30 seconds.
After the following 10 seconds (8 pulses are shown), I use 7, 6 and 8 pulses... so 21 pulses again...
At this moment the accuracy isn't as fast as I want to... So If I turn on some lamps and watercooker, it takes very long before the consumption is shown, sometimes the lamps and cooker are off again, and then the consumption starts to rise, and takes a while again before it drops again...
