Motion Light Off after 2 minutes at Nighttime
dbmet
Post by dbmet » Wednesday 29 August 2018 2:45
I'm looking for a script that will turn the hallway light off after no motion for 2 minutes only when its nighttime out.
Searched the forums but didnt really see what I was looking for..
pvm
Domoticz version: Stable
Post by pvm » Wednesday 29 August 2018 7:58
Sorry wrong answer
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
dbmet
Re: Motion Light Off after 2 minutes at Nighttime
Post by dbmet » Thursday 30 August 2018 17:35
Ehhh figured it out using smart lua scripts. I think.
snellejellep
Target OS: Raspberry Pi
Domoticz version: 3.97xx
Post by snellejellep » Thursday 30 August 2018 18:54
can you give some examples for others browsing the forum with a similar question?
raspberry pi | xiaomi gateway/vacuum | yeelight | philips hue | zwave |ubiquiti unifi | harmony
Post by waaren » Friday 31 August 2018 19:37
From the dzVents wiki:
"A device trigger can have a time-rule constraint: on = { devices = { ['myDevice'] = 'at nighttime' } }. This only triggers the script when myDevice was changed and the time is after sunset and before sunrise."
so if you use this as the on = section and something like
if trigger.state == "On" then
  	domoticz.devices("hallway light").switchOn().checkFirst()
	domoticz.devices("hallway light").switchOff()
in the execute = section (assuming the motion detector switches to "Off" after two minutes.) If that is not the case the script becomes a bit more compicate with either a uservar or openURL .
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
in the execute = section (assuming the motion detector switches to "Off" after two minutes.) If that is not the case the script becomes a bit more complicated with either a uservar or openURL .
Boredcat
Domoticz version: 3.9639
Post by Boredcat » Saturday 15 September 2018 10:08
@Warren : That solution will not work.
He wanted to switch off a light when there is no motoin (so no device trigger).
A solution that I use is to use a timed event (my PIR check runs every minute). So a solution might be.
    active = true,
        timer = {'Every minute '}
    execute = function(domoticz)
    if ( ( domoticz.devices('PIR Hallway').lastUpdate.minutesAgo => 2 ) and  (domoticz.devices('Hallway').state == 'On'  and domoticz.time.isNightTime)) then
    domoticz.devices('Hallway').switchOff()
No sure if the time-rule works with a timer. (might try this)
timer = {'[Every minute ', 'at nighttime' ]}
RFXCom(E) - Yeelight Lights - KaKu / Alexa HA Bridge
Windows 2012 / Windows 2012R2 / Xpenology/ Pi 3 / Milight / Home build ESP8266 / Sonoff
Post by waaren » Saturday 15 September 2018 11:13
@waaren : That solution will not work.
As always .. It depends :D That's why I wrote "(assuming the motion detector switches to "Off" after two minutes.)"
My motion detectors also trigger an event after the set time folowing a motiondetection passed.
DomoRies
Post by DomoRies » Sunday 16 September 2018 12:34
For me this works perfectly. Maybe u can use it. This way the lights stay on for 1 minute after motion sensor detected motion.
return { on = { devices = {motion sensor} },
local light = domoticz.devices(light u want to switch)
if ((not light.active and device.active) or (light.active and device.active)) then
light.switchOn()
elseif (not device.active) then light.switchOff().checkFirst().afterMin(1) end
end }
Verstuurd vanaf mijn Moto G (5) Plus met Tapatalk
