mqtt : "stop" value implemented for blinds
mrelfire
Post by mrelfire » Sunday 26 August 2018 7:40
Is it possible to have the "Stop" value implemented to allow blinds to be manipulated with mqtt ?
example :
2018-08-25 10:11:19.678 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":149,"switchcmd":"Stop"}
today we have this error
2018-08-25 10:11:19.678 Error: MQTT: Invalid data received!
so we have the same command either in http or mqtt ?
thanks in advance
mrelfire
Re: mqtt : "stop" value implemented for blinds
Post by mrelfire » Sunday 02 September 2018 10:31
I have proposed" if it is possibl"e to had the "stop" value , but perhaps people can have some other suggestions ?
@developpers => is it complicated ? feasible ?
thans in advance ;)
ben53252642
Post by ben53252642 » Sunday 02 September 2018 12:30
You could achieve stop using levels via MQTT (although I agree with your proposal).
viewtopic.php?f=68&t=23607&start=20#p188171
Look at the Node-Red example for the Xiaomi button (import it).
There may be levels for the blind switch you can simply send, eg an to turn a simple on off switch on would usually be level 255 and to turn it off would usually be level 0 (can vary).
Is there a level number for the stop?
mrelfire
Post by mrelfire » Sunday 02 September 2018 19:12
unfortunately no.
"We" need a "stop" implementation ;)
ben53252642
Post by ben53252642 » Sunday 02 September 2018 19:50
unfortunately no.
If you really need it, you can indeed do it via levels.
Create a selector switch then map it using Lua to stop the blind, control the selector switch via MQTT.
Not the easiest way I know but it would work.
mrelfire
Post by mrelfire » Monday 03 September 2018 8:20
I have 15 blinds. followinf your suggestion I will have to create 15 others switches for levels , wich I map to my first 15 ids => a nightmare
now I have as script which swith for open on mqtt calls, and for off on https calls
not clean but in waiting as you sayed
