Editing switches doesn't work
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
astra
Target OS: Raspberry Pi
Post by astra » Saturday 25 August 2018 17:05
When I'm trying to edit switches the save button doesn't work no matter what I try. Doesn't matter what kind of switch it is.
Error in the Chrome console:
angular.min.js:124 ReferenceError: b64DecodeUnicode is not defined
at DeviceLightEdit.js:495
at angular.min.js:137
at m.$digest (angular.min.js:148)
at m.$apply (angular.min.js:151)
at l (angular.min.js:103)
at t (angular.min.js:108)
at XMLHttpRequest.A.onload (angular.min.js:109) "Possibly unhandled rejection: {}"
SweetPants
Domoticz version: V4.10069
Re: Editing switches doesn't work
Post by SweetPants » Saturday 25 August 2018 17:16
BTW, did follow you follow the RED forum rules?
Did you recently upgrade?
goto www/js folder
if domoticz.js exists, keep it
if domoticz.js.gz exists delete it
restart domoticz
clear browser and app cache
try again
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Post by waaren » Sunday 16 September 2018 11:37
bennyparker wrote:
Sunday 16 September 2018 10:59
They're all dummy "Selector Switch" and I just realizethat the switches where the "Edit" button works are just "Switch", in all the "Selector Switches" the "Edit" button doesn't work.
Are they intended to work this way?
I've tried with Chrome and the behavior is the same.
On my systems (RPI-3 Debian stretch / domoticz 4.9999) the edit buttons for selector type switches are just working fine.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
chaimeichini
Post by chaimeichini » Tuesday 02 October 2018 16:44
Clear your cache – if this doesn’t work, go ahead and disable your cache for the time being while you troubleshoot this problem.
Update or reinstall WordPress – If for some reason, you are unable to reinstall WordPress through the dashboard, you will need to manually install a fresh copy through FTP or your file manager.
Update your WordPress plugins
If you get to this step without success, you will need to take some more drastic steps to diagnose the problem. If you run a busy website, you may want to consider 1). putting the site in maintenance mode or 2). copying your site to another location where you can run some tests.
Disable ALL of your plugins and reactivate them one-by-one – yes, this sounds horrible, doesn’t it? But chances are high that you WILL discover that one of your plugins is acting up. When you identify the misbehaving plugin you will probably need to find an alte
https://subwaysurfers.vip/ https://psiphon.vip/ https://hillclimbracing.vip/
Users browsing this forum: No registered users and 7 guests
