Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Sway06
Target OS: Raspberry Pi
Domoticz version: 4.9700
Post by Sway06 » Friday 17 August 2018 19:52
How can I find this wallplug in Domoticz when using Rfxtrx433E transceiver? I don't have any remote control and when I use the learn switch function and click on the plug button it just times out and does not recognize it. Thanks for your help!
b_weijenberg
Re: Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Post by b_weijenberg » Saturday 18 August 2018 10:27
check with RFXmngr if you can pair it using Lighting2 - Anslut and try with a few different ID's
reset the module to remove all paired remotes.
RFXtrx433, RFXtrx433E
bjacobse
Post by bjacobse » Sunday 19 August 2018 22:22
Why not purchase a new set from Jula, SEK 149 (might be easiest and fastest)
and then you get 2 wallplugs and a remote. then you can use the remote to program your Rfxtrx433 gateway
https://www.jula.se/catalog/el-och-bely ... re-408084/
