forbidden errror Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pvklink
Target OS: Raspberry Pi
forbidden errror
Post by pvklink » Saturday 11 August 2018 22:30
Version: I Use the latest domoticz beta version
Platform: on a raspberry pi 3
Description:
action_1
When i use the following command on my telefhone from the wan
This works:
http://wan_ip:<port> and i have to type my username and pwd and i get the domoticz menu
action_2
When i type:
http://<user>:<pwd>@wan_ip:<port>/json.htm?type=command&param=switchlight&idx=<id>&switchcmd=On
I get a forbidden error.
My router and firewall seems to be ok otherwise i could not connect to the server with action_1...
Somebody an idea?
I need to access from the wan because i like to use google assistant from my telephone with iFTTT to use my domoticz by voice...
pvklink
Re: forbidden errror
Post by pvklink » Sunday 12 August 2018 11:24
It does worj now from behind my LAN.
It seems that you can only use de domoticz web username and pwd and not the other user accounts
I cleared the cache
i first logged off from domoticz before executing the http/json command
and after that i used the next command:
http://<user:pwd>@<ip:port>/json.htm?type=command&param=switchlight&idx=<id>&switchcmd=On
I also used a wrong json command for devices and groups. I read this:
http://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
Even my telephone with Google assistent and IFTTT works now!
Last problem is that this solution is not very secure, usernames and passwords are going plain over the internet..
Anybody some tips on this?
Is creating an local google assistent with raspberry pi a solution ?
dswinton
Post by dswinton » Sunday 12 August 2018 15:10
Hi @pvklink
This might be a solution to the username and password issue:
https://github.com/dswinton/domo-ifttt
You can use a passphrase to authenticate access from IFTT to hook up your Google home. This also effectively limits what can be done from the internet (device on/off, no other possible Domoticz commands or device listing, etc.).
Also, I'd strongly recommend using HTTPS rather than HTTP, that way your stuff is encrypted, rather than in the clear.
pvklink
Post by pvklink » Saturday 25 August 2018 19:13
thanks!
I already use IFTTT on my cellphone togeter with google assistent and webhooks
Do I understand it well that i have to add:
1) webserver on my domoticz server
2) add the php script to it and
3) instead that IFTTT on my cellphone has a real username/pwd is has another secret and communicates with the webserver
4) the real secret is on my webserver(script) on my domoticz server ?
If so, i have 2 big challenges !
1) how to make SSL working on my current domoticz. I did that about 2 years ago and that was a lot of work with letsencrypt etc.
i adjust my router and
changed domoticz.sh on the root of the domoticz folder with
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
I can now connect to my domoticz with https://ip:443 .. i get a red triangle in front of the https command, is this still encrypted ?
2) how to add a webserver to my domoticz ( i know how to port forward and add the php as proposed)
sudo apt install apache2
sudo nano /etc/apache2/ports.conf changed ports
sudo nano /etc/apache2/sites-enabled/000-default.conf (changed ports)
sudo apt install php7.0 libapache2-mod-php7.0 php7.0-mysql php7.0-gd php7.0-opcache
sudo systemctl restart apache2
now trying to add the script to it and try if all the stuff works
Users browsing this forum: No registered users and 5 guests
