forbidden errror Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pvklink
Target OS: Raspberry Pi
forbidden errror
Post by pvklink » Saturday 11 August 2018 22:30
Version: I Use the latest domoticz beta version
Platform: on a raspberry pi 3
Description:
action_1
When i use the following command on my telefhone from the wan
This works:
http://wan_ip:<port> and i have to type my username and pwd and i get the domoticz menu
action_2
When i type:
http://<user>:<pwd>@wan_ip:<port>/json.htm?type=command&param=switchlight&idx=<id>&switchcmd=On
I get a forbidden error.
My router and firewall seems to be ok otherwise i could not connect to the server with action_1...
Somebody an idea?
I need to access from the wan because i like to use google assistant from my telephone with iFTTT to use my domoticz by voice...
pvklink
Re: forbidden errror
Post by pvklink » Sunday 12 August 2018 11:24
It does worj now from behind my LAN.
It seems that you can only use de domoticz web username and pwd and not the other user accounts
I cleared the cache
i first logged off from domoticz before executing the http/json command
and after that i used the next command:
http://<user:pwd>@<ip:port>/json.htm?type=command&param=switchlight&idx=<id>&switchcmd=On
I also used a wrong json command for devices and groups. I read this:
http://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
Even my telephone with Google assistent and IFTTT works now!
Last problem is that this solution is not very secure, usernames and passwords are going plain over the internet..
Anybody some tips on this?
Is creating an local google assistent with raspberry pi a solution ?
dswinton
Post by dswinton » Sunday 12 August 2018 15:10
Hi @pvklink
This might be a solution to the username and password issue:
https://github.com/dswinton/domo-ifttt
You can use a passphrase to authenticate access from IFTT to hook up your Google home. This also effectively limits what can be done from the internet (device on/off, no other possible Domoticz commands or device listing, etc.).
Also, I'd strongly recommend using HTTPS rather than HTTP, that way your stuff is encrypted, rather than in the clear.
Users browsing this forum: Dingetje2004 and 8 guests
