How can I use a string as an attribute.
BertB
Target OS: Raspberry Pi
Post by BertB » Saturday 11 August 2018 16:50
I started working with dcVents a couple of days ago. I love it, but I want to do something with reading a devices attributes and don't know how to.
In a function, I parse through a variable with the names of devices I want to read. That works well, but from some devices I want to read the state and from others I like to read a value like current or color or whatever.
So, I read the devices description and in the first line, I wrote the name of the attribute I need to read.
Lets assume I have a switch named Switch1, of which I want to read the nValue.
I can turn the string 'Switch1' into a device with MyDevice = domoticz.devices('Switch1')
When I read the descriptiption I can put the desired attribute into another string like MyAttrib = MyDevice.description. That works fine, but MyAttrib is not a real attribute, so MyValue=MyDevice.MyAttrib does not work.
Is this possible at all?
Thanks,
Bert
Re: How can I use a string as an attribute.
Post by waaren » Sunday 12 August 2018 17:27
Thanks,
Bert
@Bertb,
Your MyDevice is a lua table with all attribute names as keys.
So the correct syntax for your requirement is
MyValue = MyDevice[MyAttrib]
tested and working (version V4.9796) with
      timer = { 'every minute'
   execute = function(dz)
      local sensor = dz.devices('temperatuur Rotterdam')
      local attribute = "temperature"
      dz.log(sensor[attribute])
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
BertB
Post by BertB » Sunday 12 August 2018 19:16
Thank you so mutch for pointing me in the right direction
Users browsing this forum: Google [Bot] and 4 guests
