EVO Home not updating
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
JuanUil
Target OS: Raspberry Pi
Domoticz version: 2.xx
Post by JuanUil » Saturday 11 August 2018 13:10
Hi, since updating to 9816 my evohome RV's are not updated anymore.
status keep staying on "Permanent override". In the switches tab I can change the status but on the floorplan no update of the changes.
Also temp graphs of the EVO are not displayed anymore.
Jan
JuanUil
Re: EVO Home not updating
Post by JuanUil » Sunday 12 August 2018 17:03
Nobody having this issue?
Or have a solution?
gordonb3
Domoticz version: Custom
Post by gordonb3 » Sunday 12 August 2018 19:12
Still on 9700 base version. So no, not (yet) having the issue.
You're not saying what hardware type though. Domoticz supports four different ways to connect to Evohome. Which one(s) are you using?
philchillbill
Post by philchillbill » Sunday 12 August 2018 21:56
HGI80 works ok with the latest Beta.
NUC/Ubuntu, Evohome Heating + HGI80, Evohome Security, 4x HikVision IP cams, Aeotec, Neo & Fibaro Z-Wave, Logitech Media Server (on Synology DS916+), 10x SqueezeBox, Kodi, Harmony Hub, 5x Amazon Echo, HA-Bridge, Hue.
StanHD
Post by StanHD » Monday 13 August 2018 8:30
This actualy started happening to my system whilst still on stable. I use HGI 80. Same problem as described. I power cycled the HGI 80 which worked and now all is ok.
I upgraded to latest beta over the weekend and all Evohome / Domoticz working fine except none of the Evohome devices logs would display. This required a manual clearing of the caches in Chrome. Now all working satisfactory.
Domoticz Slave - Asrock Ion - Linux, Python:- Broadlink RM2, Sonos
philchillbill
Post by philchillbill » Monday 13 August 2018 10:52
Do you have your HGI 80 assigned to a persistent USB port or does it change every time you restart?
JuanUil
Post by JuanUil » Monday 13 August 2018 18:37
I don't have a HGI 80
philchillbill
Post by philchillbill » Friday 17 August 2018 14:46
I spoke too soon. I see the current data for all Evohome zones, but the log/history is empty. Clearing the Appcache didn't help.
JuanUil
Post by JuanUil » Sunday 19 August 2018 9:40
Same with me,
no graphs no updating
StanHD
Post by StanHD » Sunday 19 August 2018 10:42
This is a bit strange.
I can get graphs on my Surface Pro:-
But I can't get them working on my Work PC or my Android tablet. I have tried clearing appcache etc and using incognito mode in Chrome, also tried IE but no results. I can't figure it out.
gordonb3
Post by gordonb3 » Sunday 19 August 2018 14:05
So effectively you are saying that the data is in fact there and this is a client issue?
Did you also clear the browser cache? Renewing the appcache will still reference the browser cache to save on bandwidth while recreating it. If there is anything in there that has an incorrect (newer) timestamp then Domoticz will return an OK on using the cached version and the GUI may be crippled.
StanHD
Post by StanHD » Sunday 19 August 2018 15:02
gordonb3 wrote:So effectively you are saying that the data is in fact there and this is a client issue?
Confirmed, just cleaned browser cache (Chrome) "All Time", a couple of times. No log graphs for Evohome data however the custom graph works and other sensors log graphs are working. Will keep searching .......Image
JuanUil
Post by JuanUil » Wednesday 22 August 2018 14:38
I also tried several browsers and cleaned the cache with no result :?: :?:
gordonb3
Post by gordonb3 » Thursday 23 August 2018 10:29
Right. From above posts I figured you'd be looking at an empty graph, but after installing the latest beta on a test machine I now see that there is in fact no graph at all. It's an empty page that only shows the device name. Looking at Firefox web console I can also see that it is not fetching the graph data so it would appear that someone somewhere changed the decision parameters on this and evohome zones are no longer treated similar to temperature devices.
Post by waaren » Thursday 23 August 2018 10:44
Luckily the data is still there in the database. Are you reporting this as an issue at GIT ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
gordonb3
Post by gordonb3 » Thursday 23 August 2018 13:21
Been doing some digging. When using the 9700 web content with current beta the graphs are shown. It appears that the log facility in the Web GUI was completely reorganized and Evohome's devicetype was not added to the list of temperature devices.
The complication here is that the associated devicetype - `Heating` - also includes devices that are not Temperature devices, so this is not going to be an easy fix.
Edit: I think I got it. PR on GitHub
gordonb3
Post by gordonb3 » Thursday 23 August 2018 18:24
PR added to mainline.
If you don't like to wait or build a new version first, since this change affects the www pages only you can simply apply the patch to your current installation. Remember to reload your appcache afterwards.
JuanUil
Post by JuanUil » Friday 24 August 2018 12:23
How do you apply this patch.
sorry not so good in programming :oops: :oops:
Post by waaren » Friday 24 August 2018 12:59
Solved in V4.9926 by gordonb3
for chrome browser after update:
clear cache
[ctrl] + [F5]
clear appcache
chrome://appcache-internals/#clear
and also clear Browsing data:
[ctrl] + [shift] + [delete] -->Advanced
Choose
"cookies and other site data"
"cached images and files"
"hosted app data"
[Clear data]
philchillbill
Post by philchillbill » Friday 24 August 2018 13:52
Thanks Waaren !
Users browsing this forum: No registered users and 5 guests
