Blocky script not working any more after update 4.9700 Topic is solved
madpatrick
Domoticz version: 4.9700
Post by madpatrick » Friday 10 August 2018 22:01
I've some Nodon switches with operate some lights with a blocky script.
After the upgrade these switches are not working any more.
I see in the log the switch is operated, but nothing is happening.
2018-08-10 21:54:51.732 (Zwave USB) Light/Switch (NodOn Button 3)
Image[/url]
ClearOS 7.5.0 - Toon 4.15.16 (rooted) - Domoticz 4.9700
SweetPants
Domoticz version: V4.9866
Re: Blocky script not working any more after update 4.9700
Post by SweetPants » Saturday 11 August 2018 9:57
So the Blockly is working but the switch is not. Your tittle says something different. Can you manually switch?
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
madpatrick
Re: Blocky script not working any more after update 4.9700 [solved]
Post by madpatrick » Saturday 11 August 2018 18:46
Everything was working fine. The blocky script was working and the switched were operated by the blocky script.
After the upgrade to 4.9700 the the switches were not operating any more by the script. Manually was working fine.
But, i've found the problem.
Somehow in the settings the events were not set active anymore.
When i put the check mark on active, every thing was working again.
SweetPants
Post by SweetPants » Sunday 12 August 2018 9:20
Good to hear it is working again. I think you ran into an 'old' bug where the eventsystem was switched off after upgrade. Depending on the version prior to your upgrade to V4.9700, this could well have been your problem. Can you mark this solved?
