[Solved] Zipato RGBW bulb 2 no rgb function
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
peet3kabo
Post by peet3kabo » Friday 10 August 2018 17:28
I have the bulb mentioned in the title and have another topic about this problem:
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Domoticz only sees the bulb as a led dimmable bulb and that is the only function that I get.
Read somewhere that Domoticz doesn't completly support this bulb yet.
Something that might be solved in the near future?
Would like to use it as an RGBW bulb like it supported to be used like.
Edit:
Solution:
Got an answer from somebody to adjust the RGBBulb2.XML file.
You can find the answer here:
https://gathering.tweakers.net/forum/li ... es/1869961
Adjust config file for Zipato Bulb2 (~/domoticz/Config/ZipatoRGBBulb2.xml). The <CommandClass id="51"> needs to be replaced with the following:
<CommandClass id="51" name="COMMAND_CLASS_COLOR" version="1" request_flags="2" innif="true" colorchannels="31">
 <Instance index="1" />
 <Value type="string" genre="user" instance="1" index="0" label="Color" units="#RRGGBBWWCW" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="#8888000000" /> <Value type="list" genre="user" instance="1" index="1" label="Color Index" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="17" size="0">
      <Item label="Off" value="0" />
      <Item label="Cool White" value="1" />
      <Item label="Warm White" value="2" />
      <Item label="Red" value="3" />
      <Item label="Lime" value="4" />
      <Item label="Blue" value="5" />
      <Item label="Yellow" value="6" />
      <Item label="Cyan" value="7" />
      <Item label="Magenta" value="8" />
      <Item label="Silver" value="9" />
      <Item label="Gray" value="10" />
      <Item label="Maroon" value="11" />
      <Item label="Olive" value="12" />
      <Item label="Green" value="13" />
      <Item label="Purple" value="14" />
      <Item label="Teal" value="15" />
      <Item label="Navy" value="16" />
      <Item label="Custom" value="17" />
  </Value>
  <Value type="int" genre="system" instance="1" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="31" />
</CommandClass>
Edit:
Don't know how to get the code visible yet, working on it.
Verstuurd vanaf mijn SM-G935F met Tapatalk
Users browsing this forum: manjh, StanHD and 7 guests
