Buying a new weather Station
Kartes
Target OS: Raspberry Pi
Post by Kartes » Thursday 09 August 2018 20:33
Hey all,
I'm quite new to this forum and i need a some help. I've got an Eurochron EIWS 1 in my garden that only works with the Wundergrounds API. I recently found out that the API keys used to be free but now they're not. That's why i am looking for a replacement for my current Eurochron.
I'm looking for something like i have at the moment, i've found some stations but they have several individual sensors, i'm looking for one complete unit. I need a bit of help on buying one.
I need to be able to connect it to an API so that i can use the data from the station in Domoticz.
lotte3500
Domoticz version: 4.9700
Re: Buying a new weather Station
Post by lotte3500 » Thursday 09 August 2018 22:14
If your station is sending data to weather underground I am guessing that it is using WiFi to do so.
I have the weatherstation Ventus W830, which is also sending data to weather underground using WiFi. I am able to intercept this data using weeWX (http://www.weewx.com/).
I use the weeWX intercepter extension to extract the URL that is being send to weather underground.
https://github.com/matthewwall/weewx-interceptor
At this point you have extracted the weather station data locally. Which can also be seen in a web page for example.
For weeWX there is also an extension that can upload data to an MQTT broker
https://github.com/weewx/weewx/wiki/mqtt
I installed mosquitto and I am using Node-RED to listen to these messages and translate them into JSON strings that domoticz can understand.
https://www.domoticz.com/wiki/MQTT
For me it is working very well, it sends messages to domoticz every 10 seconds give or take.
Although you have another weather station, I think this approach will work for every WiFi weather station.
Kartes
Post by Kartes » Thursday 09 August 2018 22:30
wow, this looks interesting... The main reason for me to buy a new weatherstation was that WU isn't giving free API keys anymore. I'm going to try your solution first before i'm buying a new one. Thanks a lot!
