thermometer logs empty Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
commentator
Target OS: Raspberry Pi
Post by commentator » Thursday 09 August 2018 16:32
Version: V4.9815
Platform: rpi raspbian
Plugin/Hardware: rflink
Description: after update to V4.9815 (and offcourse clearing the cache) the thermomters logs are all empty
commentator
Re: thermometer logs empty
Post by commentator » Thursday 09 August 2018 16:35
Restoring the previous domoticz version (without replacing the db) doesn't fix the problem
f99mlu
Post by f99mlu » Thursday 09 August 2018 17:10
Same has happened to me. No temperature graphs can be seen using my web browsers.
commentator
Post by commentator » Thursday 09 August 2018 17:11
Update: with the android app the graphs are still there so it is a webpage/server issue
f99mlu
Post by f99mlu » Thursday 09 August 2018 17:12
I agree. I can also see graphs using the android app. but only there.
SweetPants
Domoticz version: V4.9895
Post by SweetPants » Thursday 09 August 2018 17:50
Already noticed this in V4.9805
Probably related to commit: #b5049dc
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
f99mlu
Post by f99mlu » Thursday 09 August 2018 20:16
Hoping for a fix tonight.. miss my lovely temperature graphs. thanks! :)
commentator
Post by commentator » Friday 10 August 2018 8:19
solved in V4.9816
f99mlu
Post by f99mlu » Friday 10 August 2018 8:27
Yes :D . It works for me too now.
SweetPants
Post by SweetPants » Friday 10 August 2018 8:28
solved in V4.9816
Not quite if you use Weather Undergroud. This places a Wind sensor under Temperature tab showing temperatures. This log is still empty. Reported this back on Github
SweetPants
Post by SweetPants » Friday 10 August 2018 9:18
WU Wind should be fixed in V4.9817, case closed
@commentator, could you close this issue?
Users browsing this forum: peteralm and 7 guests
