[SOLVED]BETA: 4.9811 crashes on startup Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Lizard
Target OS: Raspberry Pi
Post by Lizard » Thursday 09 August 2018 11:05
On my rpi 3 the latest beta crashes on startup.
This is the output when I try to start Domoticz manually:
2018-08-09 11:04:40.200  Status: Domoticz V4.9811 (c)2012-2018 GizMoCuz
2018-08-09 11:04:40.201  Status: Build Hash: 374561fe, Date: 2018-08-09 07:45:25
2018-08-09 11:04:40.201  Status: Startup Path: /home/pi/domoticz/
2018-08-09 11:04:40.306  Sunrise: 06:11:00 SunSet: 21:13:00
2018-08-09 11:04:40.306  Day length: 15:02:00 Sun at south: 13:05:00
2018-08-09 11:04:40.306  Civil twilight start: 05:32:00 Civil twilight end: 21:52:00
2018-08-09 11:04:40.306  Nautical twilight start: 04:40:00 Nautical twilight end: 22:44:00
2018-08-09 11:04:40.306  Astronomical twilight start: 03:34:00 Astronomical twilight end: 23:50:00
2018-08-09 11:04:40.306  Status: EventSystem: reset all events...
2018-08-09 11:04:40.425  Status: PluginSystem: Started, Python version '3.5.3'.
2018-08-09 11:04:40.433  Error: Domoticz received fatal signal 11 (Segmentation fault)
2018-08-09 11:04:43.786  Error: Thread 1 (Thread 0x763a4000 (LWP 12785)):
2018-08-09 11:04:43.786  Error: #0  0x76ea64cc in __waitpid (pid=12788, stat_loc=0x7eb2b620, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
2018-08-09 11:04:43.786  Error: #1  0x00228abc in dumpstack_gdb() ()
2018-08-09 11:04:43.786  Error: #2  0x00228f1c in signal_handler(int, siginfo_t*, void*) ()
2018-08-09 11:04:43.786  Error: #3  <signal handler called>
2018-08-09 11:04:43.786  Error: #4  0x76ea7b80 in pthread_setname_np (th=0, name=0x7eb2be08 "AsyncSer_Backgr") at ../sysdeps/unix/sysv/linux/pthread_setname.c:47
2018-08-09 11:04:43.786  Error: #5  0x002602d8 in SetThreadName(unsigned long, char const*) ()
2018-08-09 11:04:43.786  Error: #6  0x003d4b1c in AsyncSerialImpl::AsyncSerialImpl() ()
2018-08-09 11:04:43.786  Error: #7  0x003d2c34 in AsyncSerial::AsyncSerial() ()
2018-08-09 11:04:43.786  Error: #8  0x0052f948 in RFXComSerial::RFXComSerial(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int) ()
2018-08-09 11:04:43.786  Error: #9  0x00290290 in MainWorker::AddHardwareFromParams(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, _eHardwareTypes, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned short, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, int, int, int, int, int, bool) ()
2018-08-09 11:04:43.786  Error: #10 0x00290b74 in MainWorker::AddAllDomoticzHardware() ()
2018-08-09 11:04:43.786  Error: #11 0x00290e14 in MainWorker::Start() ()
2018-08-09 11:04:43.786  Error: #12 0x001e1b68 in main ()
2018-08-09 11:04:43.787  Error: #5  0x002602d8 in SetThreadName(unsigned long, char const*) ()
2018-08-09 11:04:43.787  Error: #6  0x003d4b1c in AsyncSerialImpl::AsyncSerialImpl() ()
2018-08-09 11:04:43.787  Error: #7  0x003d2c34 in AsyncSerial::AsyncSerial() ()
2018-08-09 11:04:43.787  Error: #8  0x0052f948 in RFXComSerial::RFXComSerial(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int) ()
2018-08-09 11:04:43.787  Error: #9  0x00290290 in MainWorker::AddHardwareFromParams(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, _eHardwareTypes, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned short, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, int, int, int, int, int, bool) ()
2018-08-09 11:04:43.787  Error: #10 0x00290b74 in MainWorker::AddAllDomoticzHardware() ()
2018-08-09 11:04:43.787  Error: #11 0x00290e14 in MainWorker::Start() ()
2018-08-09 11:04:43.787  Error: #12 0x001e1b68 in main ()
Segmentation fault
heggink
Domoticz version: V4.9999
Re: BETA: 4.9811 crashes on startup
Post by heggink » Thursday 09 August 2018 12:06
and 4.9812 as well...
Created a bug on github: https://github.com/domoticz/domoticz/issues/2620
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
Lizard
Post by Lizard » Thursday 09 August 2018 12:09
V4.9814 also crashes
PA3FAT
Post by PA3FAT » Thursday 09 August 2018 12:15
My system became fully unreachable. Has hardcoded dhcp in my router to get n.n.1.40 but cannot connect anymore.
Any options to find out how to connect to it so i can upgrade the crash fix when it becomes available?
SweetPants
Domoticz version: V4.10267
Post by SweetPants » Thursday 09 August 2018 13:33
Not getting an IP address has nothing to do with this crash. Only the domoticz process crashes and your RPi should still be reachable. Can you ping your RPi?
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
a3vd
Post by a3vd » Thursday 09 August 2018 13:37
4.9814 crashes here also can't find anything strange in the log files
Raspberry B / Raspberry B+ / Raspberry 2 / Raspberry 3 / Raspberry 3+
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12
Several Kaku switches/ Weather Underground / Razberry / 2 Everspring 142 dimmers
PA3FAT
Post by PA3FAT » Thursday 09 August 2018 14:03
@sweetpants.
Can even no longer ping the rpi. It seems to start booting, but cannot connect in any way.
SweetPants
Post by SweetPants » Thursday 09 August 2018 14:16
@sweetpants.
That is weird, the reported crash is domoticz only related. Everything else should just work fine. From a distance it's hard to tell what is going on. Maybe you can connect a keyboard and screen and see if you get some messages there?
PA3FAT
Post by PA3FAT » Thursday 09 August 2018 14:19
@sweetpants,
Not that easy but will see what i can do. It's currently in the cupboard where all the electricity/internet comes into the house....
In via keyboard/tv hdmi, it logs in into grafical interface can enter my id/password and after that i can ping it.
Rebooted. Same login prompt on tv but also i can ping it. Did already try ./updatebeta. But graphical interface of Domoticz is still not there. Needs to wait for fix. Seems i can handle it from here (for now :) )
SweetPants
Post by SweetPants » Thursday 09 August 2018 14:38
@sweetpants,
Great you have it back. Yes, latest Beta will crash right after startup. Already reported on Github, waiting for a quick fix.
commentator
Post by commentator » Thursday 09 August 2018 15:24
@sweetpants,
that updates something but it is still crashing
Lizard
Post by Lizard » Thursday 09 August 2018 15:44
v4.9815 solves the crashes.
Jurik
Domoticz version: latest
Post by Jurik » Thursday 09 August 2018 15:46
same for me, no crash anymore
PA3FAT
Post by PA3FAT » Thursday 09 August 2018 16:08
resolved here also, tnx all !
Snowtiger
Domoticz version: 3.8363
Post by Snowtiger » Thursday 09 August 2018 16:19
./updatebeta - restart and running V4.9815 - problem solved ;)
Thx Image
m147
Post by m147 » Thursday 09 August 2018 17:03
According recommendation, I have installed Domoticz on Debian Squeez. There appeared problem with installation.
Precompiled Domoticz required libssl.so.1.0.0 library but Squeez has newer version viewtopic.php?t=22303. So I compiled Domoticz from source without any problem since now.
After upgrade I cannot start Domoticz, it require libssl.so.1.0.0 again.
Is that mean, for upgrade I have to comiple it again?
Is there any possibility to repair this depedency in future update?
SweetPants
Post by SweetPants » Thursday 09 August 2018 17:44
Please do not hijack an existing topic but open a new one, this crash is resolved in V4.9815.
BTW, how did you upgrade, Using git pull && make (as you compiled by source) or binary update?
m147
Post by m147 » Thursday 09 August 2018 17:54
OK I will open new topic
I updated by "updatebeta" script. Thru web interface domoticz does not see any updates.
I guess it's not proper way to update...
SweetPants
Post by SweetPants » Thursday 09 August 2018 17:58
Yes, if you compile from source then it's better to update via git (git pull && make)
SweetPants
Post by SweetPants » Thursday 09 August 2018 17:59
@lizard, can you mark this solved?
