Battery Low notification stays after replacing batteries
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
jvmaanen
Target OS: Raspberry Pi
Post by jvmaanen » Thursday 09 August 2018 10:17
Recently I received a Battery Low notifications for my Everspring SP103 Motion Sensor. The battery level was 40%. After replacing the batteries I kept receiving the Battery Low notifications. The level was still 40%. I replaced the batteries again with other new batteries and I tested these batteries before I placed them in the Motion Sensor. I still have the Battery Low notifications after two days. I still reports 40%. The wake up interval for this device is 14400 seconds (4h).
SweetPants
Domoticz version: V4.10267
Re: Battery Low notification stays after replacing batteries
Post by SweetPants » Thursday 09 August 2018 13:55
Are you sure that there is no new device with different idx after you replaced the battery? Does 'lastseen' of your device update?
Edit: Just noticed this is a Z-wave device. Don;t know if they change idx also when changing battery.
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
heggink
Domoticz version: V4.9999
Post by heggink » Thursday 16 August 2018 8:50
jvmaanen wrote:Recently I received a Battery Low notifications for my Everspring SP103 Motion Sensor. The battery level was 40%. After replacing the batteries I kept receiving the Battery Low notifications. The level was still 40%. I replaced the batteries again with other new batteries and I tested these batteries before I placed them in the Motion Sensor. I still have the Battery Low notifications after two days. I still reports 40%. The wake up interval for this device is 14400 seconds (4h).
Sounds familiar. Same sensor, same behaviour but I am hoping that it will today report accurate battery readings nearly a week after changing the batteries. I use the python plugin that creates battery devices. That took a couple of days. Yesterday domoticz finally showed 100% through json... Let's hope the low battery warnings are gone now. No idea why it took so long. Same happened with a zwave wall switch.
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
heggink
Post by heggink » Thursday 16 August 2018 12:58
Did some more testing and there's definitely a bug somewhere. Today the dzvents script still reported the low battery even though the JSON interface reports it at 100%:
        active = true,
                timer = {'at 12:54'}
logging = {
   level = domoticz.LOG_DEBUG,
   marker = "BATT "
        execute = function(domoticz)
                print('BATT: '..domoticz.devices('PIR_Garage').batteryLevel)
2018-08-16 12:54:00.665 Status: dzVents: Info: BATT : ------ Start external script: lb.lua:, trigger: at 12:54
2018-08-16 12:54:00.683 Status: dzVents: Debug: BATT : Processing device-adapter for PIR_Garage: Switch device adapter
2018-08-16 12:54:00.683 Status: dzVents: BATT: 20
2018-08-16 12:54:00.683 Status: dzVents: Info: BATT : ------ Finished lb.lua
http://192.168.1.105:8080/json.htm?type ... order=Name
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 0,
"HardwareID" : 10,
"HardwareName" : "AEOTEC",
"HardwareTypeVal" : 21,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00002300",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2018-08-16 11:41:46",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "PIR_Garage",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" : [ 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Motion Sensor",
"SwitchTypeVal" : 8,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "motion",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "490",
"YOffset" : "408",
"idx" : "351"
Pi3, latest beta
Harmony hub, Nest
SweetPants
Post by SweetPants » Thursday 16 August 2018 13:40
I assume the JSON call get's it's info from the database (can you verify this?). So then dz_Ventz get's it's data from somewhere else. Did you restart domoticz already?
heggink
Post by heggink » Thursday 16 August 2018 14:14
Not sure where json gets it from but DB seems a fair assumption. I did restart, no dice.
Whether dzvents or plain lua remains to be seen.
Pi3, latest beta
Harmony hub, Nest
SweetPants
Post by SweetPants » Thursday 16 August 2018 18:44
I think dannybloe has to take a look at this.
Post by waaren » Saturday 18 August 2018 16:46
I experienced the same. After updating to beta V4.9910 and a soft reset of my Zwave controller and a heal network (both in node management under hardware tab) and a bit of patience, the status is reported correctly again.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Users browsing this forum: No registered users and 5 guests
