SSL certificate should be purchased for domoticz.com
leecollings
Target OS: Raspberry Pi
Post by leecollings » Wednesday 08 August 2018 11:38
Hi guys,
I've just noticed that the forum (and the entire domoticz.com domain) doesn't have an active SSL certificate applied.
Can this be done at all, is there any reason why not? A Wildcard SSL would be ideal as you would then be able to use it for my.domoticz.com (which would definitely need an SSL).
Anyway we can help at all?
Egregius
Re: SSL certificate should be purchased for domoticz.com
Post by Egregius » Wednesday 08 August 2018 11:42
On the forum there's a letsencrypt certificat installed, only the redirection from http to https isn't done.
People should always use https://www.domoticz.com/forum instead of the plain text http url.
And the administrators should place a redirect from http to https.
leecollings
Post by leecollings » Wednesday 08 August 2018 12:01
Hmm, yeah I see that now, that the domain is accessible via https, but you are correct, a redirect should definitely be put in place, this is going to flag up on many SEO audit tools.
leecollings
Post by leecollings » Friday 28 September 2018 11:21
Hey, admins, the redirection to https://www still isn't happening, I naturally enter domoticz.com/forum to access this site, which loads up the non-www and non-https version.
Is this redirection set up on the cards at all?
