Problems installation domoticz
gerardsoraya
Domoticz version: v3.8763
Post by gerardsoraya » Wednesday 08 August 2018 7:19
Hello everyone,
Ik trying for several days now to install domoticz. I have tried to install it the easy way and the hard way but i get stuck after setting the ports. Is these anyone who want to help me? Im really desperate because it was working for 1,5 years perfectly and my hole house depents on the system haha.
Verstuurd vanaf mijn SM-G965F met Tapatalk
ubuntu
rflink 433 mhz
rflink 868 mhz
p1 smart meter cable
toon thermostaat
otgw
pretty noob but whit google i've done a lot
Target OS: Raspberry Pi
Re: Problems installation domoticz
Post by waaren » Wednesday 08 August 2018 8:10
Hello everyone,
Can you try to:
sudo su -
cd your domoticz dir
curl https://install.domoticz.com > domoInstall
sed -i 's#tgz "http://ww#tgz "https://ww#' domoInstall
chmod +x domoInstall
./domoInstall
this would load the install script and change the line with the command to get the binary to get it from the https site. If that fails on the download step, copy your manual downloaded tgz file to the installation dir and put an # at the beginning of the wget line and rerun the script.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Theedoek
Post by Theedoek » Thursday 09 August 2018 9:57
gerardsoraya wrote:Hello everyone,
It would help if you can actually tell us how it gets 'stuck' and what you are trying to install Domoticz on.
Do you see error messages or do you get all kinds of warnings? Is it a Windows based PC or a Raspberry Pi running Raspbian?
Please tell us what you see and maybe even post some screenshots.
gerardsoraya
Post by gerardsoraya » Thursday 09 August 2018 11:37
its an old windows pc were i putt linux mint on, first i thought the problem was because i installed the newest linux mint 19 (tara) sow i downgraded it to 17.2 cinnamon. when i use the download the easy way the next error shows up. also on the wike install.txt i doesnt work, or im doing something wrong haha. thanq for helping
gerard@gerard-Aspire-X3812 ~ $ sudo curl -L install.domoticz.com | bash
[sudo] password for gerard:
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   194  100   194    0     0   2024      0 --:--:-- --:--:-- --:--:--  2042
100 16257  100 16257    0     0  63720      0 --:--:-- --:--:-- --:--:-- 63720
::: Script called with non-root privileges. The Domoticz installs server packages and configures
::: system networking, it requires elevated rights. Please check the contents of the script for
::: any concerns with this requirement. Please be sure to download this script from a trusted source.
::: Detecting the presence of the sudo utility for continuation of this install...
::: Utility sudo located.
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for libcurl3... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev... installed!
::: Downloading Domoticz
::: Current User: gerard
HTTP Port:  8080
HTTPS Port:  443
::: Destination folder=/home/gerard/domoticz
--2018-08-09 11:30:12--  http://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=i686
Herleiden van www.domoticz.com (www.domoticz.com)... 185.27.142.198
Verbinding maken met www.domoticz.com (www.domoticz.com)|185.27.142.198|:80... verbonden.
HTTP-verzoek is verzonden; wachten op antwoord... 302 Moved Temporarily
Locatie: https://releases.domoticz.com/releases/release/domoticz_linux_i686.tgz [volgen...]
--2018-08-09 11:30:12--  https://releases.domoticz.com/releases/release/domoticz_linux_i686.tgz
Herleiden van releases.domoticz.com (releases.domoticz.com)... 146.185.159.228
Verbinding maken met releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443... verbonden.
HTTP-verzoek is verzonden; wachten op antwoord... 404 Not Found
2018-08-09 11:30:12 Fout 404: Not Found.
ubuntu
rflink 433 mhz
rflink 868 mhz
toon thermostaat
otgw
Theedoek
Post by Theedoek » Saturday 11 August 2018 15:01
I noticed that the command you entered is slightly different from the one mentioned in the wiki. The command you should be entering is
curl -L install.domoticz.com | sudo bash
gerardsoraya
Post by gerardsoraya » Sunday 12 August 2018 9:25
Theedoek wrote:I noticed that the command you entered is slightly different from the one mentioned in the wiki. The command you should be entering is
This is What the site says, i will try your advice later today. ThnqImage
ubuntu
rflink 433 mhz
rflink 868 mhz
toon thermostaat
otgw
Theedoek
Post by Theedoek » Sunday 12 August 2018 10:08
Nice, the actual wiki says something else ImageImage
Theedoek
Post by Theedoek » Monday 13 August 2018 11:57
Any updates?
