IOS add to Home screen does not work
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Okko
Target OS: Raspberry Pi
Post by Okko » Sunday 05 August 2018 14:15
Version: 4.9796 Beta
Platform: Raspberry PI
Plugin/Hardware: Raspberry Pi RFXCOM, Zwave, Philips Hue
Description: When I want to create in IOS 11 add to home screen the icon does not work. When you press the icon I get a dark screen. This happens on my iPads and several iPhones. Cache all cleared from the IOS devices. This happens when I make a link to my local server (within wifi network) and also for the link from outside my network. It is not possible to edit a web address in IOS.
I managed to make a link once by pressing stop before the webpage automatically changes to /#/Dashboard. This seems to work so my conclusion is that the icon in IOS does not work when the link to /#/Dashboard or any other link, for example /#/lightSwitches is included.
Is this an known problem or am I the only one that has this problem? I like the standard interface and would like to avoid using a native app.
SweetPants
Domoticz version: V4.10216
Re: IOS add to Home screen does not work
Post by SweetPants » Sunday 05 August 2018 14:34
Why do you think this is a Domoticz problem?
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Okko
Post by Okko » Sunday 05 August 2018 15:13
It used to work in the previous version 3.6X and you login on the interface of Domoticz. I'm just wondering if I'm the only one that has this problem. It used to work brilliant and updating to the latest beta results in this problem.
kiddigital
Domoticz version: 4.9788
Post by kiddigital » Monday 06 August 2018 18:36
I have the same problem. After going from 3.x to 4.97xx beta my iOS 11 links do not work anymore. My dashboard gets loaded but no other icons or menu options work anymore.
Using Safari directly, so no shortcut, it still works.
Must be something with the URL somehow...
One RPi with Domoticz, RFX433e, aeon labs z-wave plus stick GEN5, ha-bridge 5.1.0 for Alexa
HSR3
Domoticz version: v4.9822
Post by HSR3 » Wednesday 08 August 2018 21:41
I have the same problem. After installation of version v4.9700 domoticz at first showed correctly on my MBP. But after a short while the information disappeared showing only a blank screen with an empty selection box in the upper left corner. Same on the iPad and iPhone. It didn't matter if I started from a web browser or from a home screen icon. Domoticz, however was running correctly as could be seen in a SSH terminal.
I figured out that clearing the browser history and cookies on the MBP and iPad did bring the domoticz interface back to live when starting from a browser. Home screen shortcuts still don't work. A solution for the home screen shortcuts would be appreciated.
Jimbolaya
Domoticz version: 4.9954
Post by Jimbolaya » Friday 31 August 2018 14:36
Same problem here with Domoticz 4.9954 and my iPhone. Works OK on my iPad though.
Jim
binbo
Post by binbo » Thursday 18 October 2018 22:41
I can confirm this problem.
Domoticz Version: 4.9700
This might be an iOS 12 bug?
If you use safari to go to:
192.168.1.{whatever}:8080
Domoticz works fine.
BUT... add that path as a homescreen icon - and it won’t load.
It used to - but not anymore.
Annoying. As when used as a homescreen link - domoticz web interface almost feels like a genuine app.
Okko
Post by Okko » Sunday 11 November 2018 16:14
I'm now on beta Version: 4.10181 and it seems to work again. I can add the link to the Home Screen and the new button works!
Users browsing this forum: Bing [Bot] and 2 guests
