door switch does not create entries in device log
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
manjh
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by manjh » Sunday 05 August 2018 11:32
Info:
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.4.2 (default, Oct 19 2014, 14:03:53) [GCC 4.9.1]
I have defined a new door contact (Reed relais type) and I can see the events in the Domoticz log. Also see the "last seen" timestamp changing.
But when I look in the device log, there are no entries! Is this a setting somewhere? Something I did wrong?
Hans
SweetPants
Domoticz version: V4.9866
Re: door switch does not create entries in device log
Post by SweetPants » Sunday 05 August 2018 14:41
Nothing wrong on V4.9796, Device log reflects contact status.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
manjh
Post by manjh » Monday 06 August 2018 12:36
So why is my device log still empty? The sensor is attached to the front door, and I can see in the "last seen" timestamp that there has been activity. But still no entries in the device log.... what can be wrong?
Hans
manjh
Post by manjh » Monday 06 August 2018 12:40
Just to make sure I tried everything, I just now rebooted the R-Pi. After that I opened and closed the front door.
I can see the sensor is triggered in the Domoticz log, and also that the "last seen" timestamp is updated.
But still: device log is empty.
It doesn't make sense, but is this a setting somewhere?
Hans
SweetPants
Post by SweetPants » Monday 06 August 2018 15:41
Did you upgrade recently? If so did you follow the RED forum rules (cache thingy)? Tried incognito mode on chrome? How is your log history setup (Setup->settings->log history)?
manjh
Post by manjh » Monday 06 August 2018 18:15
No, I did not upgrade recently.
After installing the device I wanted to clear everything and start logging "real" events, and wipe out the test events. At that time I did see a couple of entries, and I cleared them using the button.
After that nothing new came in.
log history settings is standard: 15 days for light/switches, and 1 day for short log sensors.
I cleared the cache. Incognito mode does not show anything different.
Hans
SweetPants
Post by SweetPants » Tuesday 07 August 2018 8:16
Not sure if this si still the case, but can you see in domoticz/www/js :
1) if there is a file domoticz.js, keep it
2) if there is a file called domoticz.js.gz, delete it
3) restart domoticz, clear browser caches and try again
manjh
Post by manjh » Tuesday 07 August 2018 20:51
File gz does not exist.
I guess we'll never know the cause of this. After looking for the gz file, I decided to take the easy way out: I deleted the device, and re-learned the signal. The device now generates log entries OK, it seems. I will keep an eye on it...
Hans
rolleyfernandes
Post by rolleyfernandes » Saturday 11 August 2018 14:04
like to keep temperature data as long as possible but other devices like motion sensors in every room are more sensible.
It just feels wrong if you try to avoid services that track you in the internet and then implementing your own tracking system at home.
_________________________________________
VidMate AnyDesk https://mobdro.onl/download/
Last edited by rolleyfernandes on Saturday 11 August 2018 18:48, edited 1 time in total.
SweetPants
Post by SweetPants » Saturday 11 August 2018 14:49
What's the relation to the topic question/problem?
Users browsing this forum: No registered users and 6 guests
