door switch does not create entries in device log
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
manjh
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by manjh » Sunday 05 August 2018 11:32
Info:
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.4.2 (default, Oct 19 2014, 14:03:53) [GCC 4.9.1]
I have defined a new door contact (Reed relais type) and I can see the events in the Domoticz log. Also see the "last seen" timestamp changing.
But when I look in the device log, there are no entries! Is this a setting somewhere? Something I did wrong?
Hans
SweetPants
Domoticz version: V4.10069
Re: door switch does not create entries in device log
Post by SweetPants » Sunday 05 August 2018 14:41
Nothing wrong on V4.9796, Device log reflects contact status.
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
manjh
Post by manjh » Monday 06 August 2018 12:36
So why is my device log still empty? The sensor is attached to the front door, and I can see in the "last seen" timestamp that there has been activity. But still no entries in the device log.... what can be wrong?
Hans
manjh
Post by manjh » Monday 06 August 2018 12:40
Just to make sure I tried everything, I just now rebooted the R-Pi. After that I opened and closed the front door.
I can see the sensor is triggered in the Domoticz log, and also that the "last seen" timestamp is updated.
But still: device log is empty.
It doesn't make sense, but is this a setting somewhere?
Hans
SweetPants
Post by SweetPants » Monday 06 August 2018 15:41
Did you upgrade recently? If so did you follow the RED forum rules (cache thingy)? Tried incognito mode on chrome? How is your log history setup (Setup->settings->log history)?
manjh
Post by manjh » Monday 06 August 2018 18:15
No, I did not upgrade recently.
After installing the device I wanted to clear everything and start logging "real" events, and wipe out the test events. At that time I did see a couple of entries, and I cleared them using the button.
After that nothing new came in.
log history settings is standard: 15 days for light/switches, and 1 day for short log sensors.
I cleared the cache. Incognito mode does not show anything different.
Hans
SweetPants
Post by SweetPants » Tuesday 07 August 2018 8:16
Not sure if this si still the case, but can you see in domoticz/www/js :
1) if there is a file domoticz.js, keep it
2) if there is a file called domoticz.js.gz, delete it
3) restart domoticz, clear browser caches and try again
manjh
Post by manjh » Tuesday 07 August 2018 20:51
File gz does not exist.
I guess we'll never know the cause of this. After looking for the gz file, I decided to take the easy way out: I deleted the device, and re-learned the signal. The device now generates log entries OK, it seems. I will keep an eye on it...
Hans
Users browsing this forum: Google [Bot] and 5 guests
