irrigation pump
ErikAtSpijk
Target OS: Raspberry Pi
Domoticz version: 3.8153
irrigation pump
Post by ErikAtSpijk » Saturday 04 August 2018 0:12
So fed up of irrigating the garden manually. Does any one has experience with different types of irrigation pumps like the the one below?
https://www.kaercher.com/int/home-garde ... 53620.html
Do these pomp successfully start if the power is switched on of do they cavitate? Do you need to keep removing air to allow it to work? Any protection that prevent tho start if from a fibaro switch?
Thanks,
Erik
rrozema
Re: irrigation pump
Post by rrozema » Saturday 04 August 2018 6:12
According to the manual the set includes a return valve that is supposed to make sure the water stays in the input line. However it also says the pump will be damaged if it runs with no water in it and can not be run unattended. I would personally try and find some other solution.
Peterb
Re: irrigation pump
Post by Peterb » Saturday 04 August 2018 8:31
I've just finished doing the same. I used an old Hozelock garden pump that I already had (3000lph ,3.5Bar). Yes, it cavitates, and I found that it had no non-return valve. But that's all fixed now. I've installed 2000litres of rainwater storage in my basement and use said pump to run 3 toilets, garden sprinkler system, and 2 garden hoses. Provided you don't let the tanks run dry cavitation is not a problem. Adding a non return valve in front of the pump outlet plus an electronic pressure switch makes the whole thing run like a water main outlet. I'm very happy with it. Here's are some links if interested...
https://www.hozelock.com/our-products/w ... rden-pump/
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
ErikAtSpijk
Re: irrigation pump
Post by ErikAtSpijk » Sunday 05 August 2018 21:41
Thanks, intresting set up to use pomped water to flush the toilet. Good idea.
I was hoping that a fibaro switch that measures the power consumption would measure hose break and caviation (high and low power), as well as start or stop the pomp based on rain/time.
Guess I need to have a go at it.
Users browsing this forum: redfirebrooks and 5 guests
