Selector problem
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
gnomosg
Target OS: Raspberry Pi
Domoticz version: v3.5877
Selector problem
Post by gnomosg » Wednesday 01 August 2018 19:36
I have problem with selector switch after upgrade to last stable.
Linux raspberrypi 4.14.50+ #1122 Tue Jun 19 12:21:21 BST 2018 armv6l GNU/Linux
Domoticz:
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.4.4 (default, Apr 17 2016, 16:02:33) [GCC 5.3.1 20160409]
I has some problem with view of selector switch on mobile device web browser - the are not visible, switches "below" selector was not displayed too.
I try to investigate it on the forum and clear browser cache (via chrome://appcache-internals) - then selector switches disappear totally on the PC web browser also (chrome, firefox) - and about half of normal switches too... :cry:
in firefox I see error in console:
ReferenceError: b64DecodeUnicode is not defined DashboardController.js:67:5
Has anybody know solution for proper displaying selector switches?
Thanks in advance
gnomosg
01ste02
Domoticz version: 4.9700
Re: Selector problem
Post by 01ste02 » Monday 06 August 2018 10:15
Hi!
I had the same problem as you, and I thought that I should share the solution that I found.
Since b64DecodeUnicode is not defined, I simply added the function to the LightController.js (in my case, but I suspect that it will work no matter what .js file you put it in) I added the following code on line five of LightController.js:
b64DecodeUnicode = function b64DecodeUnicode(str) {
			return decodeURIComponent(atob(str).split('').map(function(c) {
			return '%' + ('00' + c.charCodeAt(0).toString(16)).slice(-2);
			}).join(''));
Then I restarted the Domoticz system, and voilá!
Hope this fixes your problem!
Oskar
gnomosg
Post by gnomosg » Tuesday 07 August 2018 23:31
Thanks for your help.
I investigate a little and found 2 files inside "domoticz/www/js" catalog:
"domoticz.js" and "domoticz.js.gz"
First one has function "b64DecodeUnicode" defined inside, but the second not!
Probably it was old file which was not removed during upgrade process, I think.
The same situation was with 3-4 another files.
After removing *.js.gz files web page works good :)
Check this :)
Thanks again Oskar :)
gnomosg
rolleyfernandes
Post by rolleyfernandes » Friday 10 August 2018 12:55
did you try with uiexplorer to see if you can find elements?
if you try on another application, lets say notepad, does it work?
__________________________________________________
https://bluestacks.vip/ https://textnow.vip/ https://photomath.vip/
Last edited by rolleyfernandes on Friday 10 August 2018 21:09, edited 1 time in total.
SweetPants
Domoticz version: V4.9866
Post by SweetPants » Friday 10 August 2018 14:08
You should delete domoticz.js.gz from www/js folder if domoticz.js is present
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Users browsing this forum: manjh, StanHD and 8 guests
