Voltage missing in latest betas Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
claude2666
Target OS: Raspberry Pi
Post by claude2666 » Wednesday 01 August 2018 14:55
Domoticz version : V4.9796
Platform: Raspberry Pi 3b, lastest Raspbian stretch lite.
Hardware : Razberry board, RFXCOM.
In the latest beta's that I have tried (V4.9796 & V4.9788) voltage is not reported anymore from my Neo Coolcam power plugs.
I have tried to exclude and include the device again, and a device with Voltage subtype is created with ID 00000001, while all others devices belonging to that plug are created with ID 0002Exx
When I go back to the stable version V4.700, the newly created voltage device with ID 00000001 stops working and a new device with ID 00002E01, voltage subtype is added. And also all other plugs start reporting voltage again.
So it looks that in the latest betas, somewhere a byte is lost in the z-wave device ID's
claude2666
Re: Voltage missing in latest betas
Post by claude2666 » Thursday 23 August 2018 17:02
The Voltage device has zwave id 00, while all other sub devices have zwave id 02. (using the latest beta's)
The problems seems be caused by the cleanup/code refactoring of 13/07 where
Where the child ID was change from an int to an unsigned byte
Old:
void SendVoltageSensor(const int NodeID, const int ChildID, const int BatteryLevel, const float Volt, const std::string &defaultname);
after update
void SendVoltageSensor(const int NodeID, const uint8_t ChildID, const int BatteryLevel, const float Volt, const std::string &defaultname);
Should the ChildID not be uint16_t?
rjblake
Post by rjblake » Wednesday 05 September 2018 14:45
I guess this is still not fixed in v4.9983. All my Aeotec Dimmer's have stopped reporting Voltages. In addition, the Z-Stick Controller now seems to have added a 'Voltage'device that is reporting/logging voltage. No idea where it is getting this info from; but it started at the same time as the voltage on the individual nano dimmers stopped.
Kender
Post by Kender » Wednesday 05 September 2018 15:43
I have the same problem: Aeotec Z-Stick has a "Voltage" device and the voltage of the CoolCAM plugs is not reported anymore :( :(
emme
Domoticz version: latest
Post by emme » Wednesday 05 September 2018 16:17
uh I though it was a personal issue :P
(not really) glad to see others has the same issue...
Aeotec DSB with 1 clamp
"We always done this way"
Robert28
Domoticz version: 4....dev
Post by Robert28 » Wednesday 05 September 2018 21:12
Nope, 2 of the 3 Neo's are not reporting a voltage anymore, 1 still does... :shock:
claude2666
Post by claude2666 » Sunday 16 September 2018 11:19
I have setup a test environment on my WIN10 workstation, and indeed, after changing ChildID to uint16_t, my Neo Coolcam plugs started reporting voltage again.
So it is clearly a bug
As I have never used github, I need to figure out how this works to try to commit the correction. Unless somebody here can help to rollback the change that was done on 13/07?
Robert28
Post by Robert28 » Sunday 16 September 2018 17:32
In which file did you change that? And were? ;)
claude2666
Post by claude2666 » Tuesday 18 September 2018 15:14
I made updates in 3 files, replacing the uint8_t for ChildID with uint16_t.
These are the updates I made to restore the reporting of the volatge:
file DomoticzHardware.h
old:
updated:
void SendVoltageSensor(const int NodeID, const uint16_t ChildID, const int BatteryLevel, const float Volt, const std::string &defaultname);
file DomoticzHardware.cpp
old:
void CDomoticzHardwareBase::SendVoltageSensor(const int NodeID, const uint8_t ChildID, const int BatteryLevel, const float Volt, const std::string &defaultname)
updated:
void CDomoticzHardwareBase::SendVoltageSensor(const int NodeID, const uint16_t ChildID, const int BatteryLevel, const float Volt, const std::string &defaultname)
file HardwareMonitor.cpp
else if (qType == "Voltage")
doffset = 1300;
float volt = static_cast<float>(atof(devValue.c_str()));
SendVoltageSensor(0, (uint8_t)(doffset + dindex), 255, volt, devName);
else if (qType == "Current")
updated:
doffset = 1300;
SendVoltageSensor(0, (uint16_t)(doffset + dindex), 255, volt, devName);
Kender
Post by Kender » Wednesday 19 September 2018 14:37
It work for me !! Thank you !! :) :) ;)
Robert28
Post by Robert28 » Wednesday 19 September 2018 21:10
Confirmed :!: :D Thanks :!: :!:
I have attached the patch files for Domoticz version 4.9999 (at the time of writing the latest unstable release). The files to patch are located in the ./hardware/ subfolder.
Domoticz_v4d9999_Patch.zip
Patch for Domoticz v4.9999 (files to patch are in ./hardware/
(891 Bytes) Downloaded 10 times
rjblake
Post by rjblake » Sunday 07 October 2018 22:33
Good news is it has been fixed in the Beta versions since 02-Oct (or possibly a day or so earlier)
Robert28
Post by Robert28 » Monday 08 October 2018 16:27
In V4.10039 (or even earlier) it is fixed. :!: :D
claude2666
Post by claude2666 » Sunday 14 October 2018 9:23
Indeed. I committed an update and it was included in the newer beta's
Users browsing this forum: No registered users and 3 guests
