Custom Python plugin stopped working after importing smbus2 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
joran
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by joran » Wednesday 01 August 2018 1:30
I'm trying to make a special plugin for my analog output board in combination with Domoticz. This worked in a separate python script, but to make the implementation better I want to build a plugin for it. This is the second plugin a made but this one is causing some problems. I wanted to use the smbus since I have used them in the script before.
Domoticz version: 4.9700
Hardware: Raspberry Pi 3 Model B Rev 1.2
OS:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
This is the old script:
#!/usr/bin/python
import smbus
import time
import requests
#I2C
bus = smbus.SMBus(1)
addressAout = 0x58
addressAin = 0x09
#Domoticz
serverIP = "10.0.0.8:8080"
OutIdx1 = "128"
OutIdx2 = "133"
OutIdx3 = "134"
OutIdx4 = "135"
InIdx2 = "129"
InIdx3 = "130"
InIdx4 = "131"
InIdx5 = "132"
username = "username"
password = "password"
#Analog output
oldCmd = "empty"
searchTerm = "LevelInt"
valLvlIndxStart = 0
valLvlIndxEnd = 0
valCmd1 = 0
valCmd2 = 0
valCmd3 = 0
valCmd4 = 0
varReq = "leeg"
bitConst = 10.23
LSB = [0,0,0,0]
HSB = [0,0,0,0]
#Analog input
inputVal = []
inputValDec = [0,0,0,0,0]
bufferSize = 0
oldVal2 = 0
oldVal3 = 0
oldVal4 = 0
oldVal5 = 0
while True:
#Get value from Domoticz
varReq = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=devices&rid=" + OutIdx1
d = requests.get(varReq)
valLvl = str(d.json())
valLvlIndxStart = int(valLvl.index(searchTerm))
valLvlIndxEnd = int(valLvl.index(',',valLvlIndxStart))
valLvlIndxStart += 10
valCmd1 = int(valLvl[valLvlIndxStart:valLvlIndxEnd])
varReq = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=devices&rid=" + OutIdx2
valCmd2 = int(valLvl[valLvlIndxStart:valLvlIndxEnd])
varReq = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=devices&rid=" + OutIdx3
valCmd3 = int(valLvl[valLvlIndxStart:valLvlIndxEnd])
varReq = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=devices&rid=" + OutIdx4
valCmd4 = int(valLvl[valLvlIndxStart:valLvlIndxEnd])
#Update value with current value
valCmdScaled = int(bitConst*valCmd1)
HSB[0] = int(valCmdScaled/256)
LSB[0] = int(valCmdScaled-HSB[0]*256)
valCmdScaled = int(bitConst*valCmd2)
HSB[1] = int(valCmdScaled/256)
LSB[1] = int(valCmdScaled-HSB[1]*256)
valCmdScaled = int(bitConst*valCmd3)
HSB[2] = int(valCmdScaled/256)
LSB[2] = int(valCmdScaled-HSB[2]*256)
valCmdScaled = int(bitConst*valCmd4)
HSB[3] = int(valCmdScaled/256)
LSB[3] = int(valCmdScaled-HSB[3]*256)
val = [LSB[0],HSB[0],LSB[1],HSB[1],LSB[2],HSB[2],LSB[3],HSB[3]]
bus.write_i2c_block_data(addressAout,0x00,val)
#Read inputs trought i2c
inputVal = (bus.read_i2c_block_data(addressAin,0x00,11))
bufferSize = len(inputVal)
inputValDec[0] = inputVal[2]*256 + inputVal[1]
inputValDec[1] = inputVal[4]*256 + inputVal[3]
inputValDec[2] = inputVal[6]*256 + inputVal[5]
inputValDec[3] = inputVal[8]*256 + inputVal[7]
inputValDec[4] = inputVal[10]*256 + inputVal[9]
#Send values to Domoticz
Val2 = inputValDec[1]
Val3 = inputValDec[2]
Val4 = inputValDec[3]
Val5 = inputValDec[4]
if (Val2 != oldVal2) :
oldVal2 = Val2
payload = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=command&param=udevice&idx=" + InIdx2 + "&nvalue=0&svalue=" + str(Val2)
r = requests.get(payload)
if (Val3 != oldVal3) :
oldVal3 = Val3
payload = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=command&param=udevice&idx=" + InIdx3 + "&nvalue=0&svalue=" + str(Val3)
if (Val4 != oldVal4) :
oldVal4 = Val4
payload = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=command&param=udevice&idx=" + InIdx4 + "&nvalue=0&svalue=" + str(Val4)
if (Val5 != oldVal5) :
oldVal5 = Val5
payload = "http://" + username + ":" + password + "@" + serverIP + "/json.htm?type=command&param=udevice&idx=" + InIdx5 + "&nvalue=0&svalue=" + str(Val5)
time.sleep(3)
This worked fine but as I said I want to make a plugin for it. The idea is that you can chance the analog output by editing a selector switch. In the script there is also a way to update the values from analog inputs of another board to Domoticz but that's not a priority.
The first problem I ran is was the python version that is used in the plugins I read that this is supposed to be python 3.5. The script ran in python 2.7 so a had to change the library I used to the newer version. After I installed smbus2 Version: 0.2.1 using pip3 Domoticz couldn't find the library. The solution for that was chancing the folder where pip3 installs the librarys to /usr/lib/python3.5/.
Then the real problem started when I uploaded the new code for the plugin (shown in the spoiler below) none of my plugins in the hardware tab would work. The would a message that the working loop started in the log but after that nothing. Not even the def onStart(self): is called. When I comment out the import smbus2 line everything works fine. Is anyone familiar with this problem? Help would be appreciated.
# Basic Python Plugin Example
# Author: GizMoCuz
<plugin key="SOM-Control_Bus" name="SOM-Control Bus" author="joran" version="1.0.0">
<description>
<h2>Plugin for SOM-Control Bus</h2><br/>
<h3>Features</h3>
<ul style="list-style-type:square">
<li>0-10V Output</li>
</ul>
</description>
<params>
<param field="Mode1" label="Address I2C Output" width="150px" required="False"/>
<param field="Mode2" label="Address I2C Input" width="150px" required="False"/>
</params>
</plugin>
import Domoticz
import smbus2
class BasePlugin:
enabled = False
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Log("onStart called")
Domoticz.Device(Name="Status1", Unit=150, TypeName="Selector Switch", Options = {"LevelActions": "||||||||||","LevelNames": "Off|10%|20%|30%|40%|50%|60%|70%|80%|90%|100%","LevelOffHidden": "false","SelectorStyle": "1"}, Used=1).Create()
Domoticz.Device(Name="Status2", Unit=151, TypeName="Selector Switch", Options = {"LevelActions": "||||||||||","LevelNames": "Off|10%|20%|30%|40%|50%|60%|70%|80%|90%|100%","LevelOffHidden": "false","SelectorStyle": "1"}, Used=1).Create()
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
def onMessage(self, Connection, Data):
Domoticz.Log("onMessage called")
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Devices[Unit].Update(Level, str(Level))
Domoticz.Log(str(Level))
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
def onHeartbeat(self):
Domoticz.Log("Heartbeat called")
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
jia175891641
Domoticz version: V3.9000
Re: Custom Python plugin stopped working after importing smbus2
Post by jia175891641 » Wednesday 01 August 2018 3:37
The problem maybe from request lib .demoticz is not supprt this lib. Delect it then try it
只要够努力 时间总会给你想要的
joran
Post by joran » Wednesday 01 August 2018 13:44
When I comment out the line import smbus2 the plugins are fine, but I need this library for I2C communications. Is there another library that I can use instead of smbus2?
joran
Post by joran » Thursday 20 September 2018 21:15
I found a workaround using only python scripts in the domoticz/scripts folder.
And I have added these scripts to level actions of my selector switch.
Users browsing this forum: No registered users and 5 guests
