dzVents - Possible to use a variable for a timed event
rbisschops
Target OS: Raspberry Pi
Domoticz version: 2.2563
Post by rbisschops » Tuesday 31 July 2018 13:06
Hi All,
As I'm using dzVents for all my Lua scripts now, i stumbled into a thought, but not sure how to do this or even if it is possible.
I created a script controling my blinds. It lowers the blinds at a fixed time in the morning and raises them in the evening. Both at a fixed time coded in the script as follows:
    active = true,
        timer = {
            'at 07:30',
            'at 17:30'
As we (the wife) wants to be able to influence the timers, I would like to put these in a variable in Domoticz. Is it possible to use the variables for the timed events. So something like:
timer = at {someVariable}
I know this code won't work, but is put in as an example to explain my thinking :-)
Thanks all for your thoughts.
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
TheCondor
Re: dzVents - Possible to use a variable for a timed event
Post by TheCondor » Friday 03 August 2018 14:44
rbisschops
Post by rbisschops » Sunday 05 August 2018 9:00
That is not exactly what i was lookling for. I want the time set in the domoticz variable to be the trigger. So 7:30 in the variable should be the trigger to kick off the script. For now I have a 15 minute time trigger and check in the script if the domo variable time is the same as the system time. This has some limitations in the time you set in the variable.
Post by waaren » Sunday 05 August 2018 21:02
I guess the solution is to read the content of the var when it changed and with that content calculate what the afterSec should be to be used with an openURL of which the repsonse will trigger the event that will do your required action and do sent the openURL in 24 hours.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
rbisschops
Post by rbisschops » Monday 06 August 2018 16:26
@waaren: but unfortunately the var does not change that often (its more a setting)
randytsuch
Post by randytsuch » Monday 06 August 2018 17:50
Define the time as a user variable of type string.
Then you can read it into dzvents
randytsuch
Post by randytsuch » Tuesday 07 August 2018 4:26
Oops, I lied
Make a user variable of type time
Then, if you can do something like this to create local variables with hours and mins, for example.
local thour = domoticz.variables('SpkrStart').time.hour
local tmin = domoticz.variables('SpkrStart').time.min
user variable is name SpkrStart in the user variable page, with value set to whatever time you want to use, ie 19:00
Post by waaren » Tuesday 07 August 2018 10:05
What you can do is trigger a script on that variable change and use the appropriate API call to delete / add the timer for that the device.
Look at the domoticz API wiki domoticz API wiki for the exact syntaxis of the calls
Post by waaren » Tuesday 07 August 2018 18:08
Something like this ?
--   setTimers.lua
    on = {   variables   =   {"timer*"}},   -- One time var for On and one for Off
    execute = function(dz,triggerObject)
        local myDevice    = 1012                      -- myDevice    = idx of myDevice
        local onTimeVar   = "timerTestOn"             -- uservariable of type time, format hh:mm
        local offTimeVar  = "timerTestOff"
        local function  clearTimers(idx)
                local api = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=cleartimers&idx=".. idx
                dz.openURL({ url = api, method = "GET" })
        local function decomposeVarTime(timeVar)
            return dz.variables(timeVar).time.hour, dz.variables(timeVar).time.minutes
        local function  setTimers(idx,sethour,setminute,state)
           local command = 0
           if state == "Off" then
            command = 1
           local api  = dz.settings['Domoticz url'] .. "/json.htm?active=true&command=" .. command ..
                                                        "&hour=".. sethour ..
                                                        "&min=" .. setminute .. "&param=addtimer" ..
                                                        "&randomness=false&timertype=2;&type=command&days=1234567&idx=" .. idx
        clearTimers(myDevice)
        local hour,minute = decomposeVarTime(onTimeVar)
        setTimers(myDevice,hour,minute)
        hour,minute = decomposeVarTime(offTimeVar)
        setTimers(myDevice,hour,minute,"Off")
randytsuch
Post by randytsuch » Tuesday 07 August 2018 21:53
rbisschops
Post by rbisschops » Thursday 09 August 2018 17:01
@waaren: Thx for setting this up. Highly appreciated!
Is it possible to do this:
As far as I understand from the documentation, its a string (even though its a date var)
What I can't figure out is why you use:
This requires one of the variables to change right? Otherwise the script won't fire.
Thx
Ralph
Post by waaren » Thursday 09 August 2018 18:28
yes this works. I tested this with uservars type time
Thx
Ralph
The idea is that when one uservar is changed a new set of timers (on/off) will be set after the current ones are cleared.
Until the uservar is changed again the timerset will stay active.
That is what I understand was your requirement.
rbisschops
Post by rbisschops » Friday 10 August 2018 8:35
Which version did you test this on (i'm on V3.9639)? I have user vars of typ time in my Domoticz, but when I add the code you propose, I get a nil value.
Post by waaren » Sunday 12 August 2018 16:55
Tested with V4.9796
