Can't write to any folder in domoticz
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Number8
Target OS: Raspberry Pi
Domoticz version: 3.5103
Post by Number8 » Monday 23 July 2018 8:03
I've been running v3.9139 for a few months without a glitch on RPi 3. I have 3 Domoticz installed. On the main one, all of a sudden I can't write anything to any folder as I was used to. Server has been rebooted without success. However as such Domoticz server is running. Is it an indication that the SD card shaal be replaced?
Thank you
freijn
Re: Can't write to any folder in domoticz
Post by freijn » Monday 23 July 2018 8:48
Are you logged in with the same user?
Show a command you are using and show the error output of it.
Can't wite is a bit too difficult to look at.
Not sure about your level of Linux.
See the owner of the directory and compare who you are.
Have you tried Sudo your command ?
Number8
Post by Number8 » Monday 23 July 2018 18:08
Thanks. Yes I'm logged with same user. No matter the logging session pi user or su, I can't write any thing to the SD card. Sounds very very strange I must admit. When I copy a file it return error 4.
HansieNL
Post by HansieNL » Monday 23 July 2018 20:30
Maybe you can try to write a file to the sd-card in a Windows PC. If you get the error the card is write protected, the card is corrupt. Than the best you can do is create a backup and install a new sd-card.
Blah blah blah
Number8
Post by Number8 » Monday 23 July 2018 22:19
I'll replace the sd card at the end of the week
Trund1980
Post by Trund1980 » Saturday 13 October 2018 11:32
I can understand your position because I was also facing this issue from last 2 months then I tried replace the card in windows but that was also not working as well.Then I followed some tips from the essayvikings.com review about this problem which worked for me for 2 days after that I still getting this issue.I don't know the correct and stable solution for this problem.
