OpenZWave command via curl
All kinds of 'OS' scripts
hamster
Target OS: Raspberry Pi
Post by hamster » Sunday 22 July 2018 22:56
Trying to figure out how to tell openzwave to 'test & heal' a node via curl. See screenshot for what I'm talking about. It shows the ozw control panel in domoticz.
I found this post, which partially explains it, but it tells how to set a function on a node, not how to execute a command on the controller itself.
If you're wondering "why," it's because I have an RGBW controller that will only get used during holidays for outdoor lighting, so I turn it off otherwise to save power. When I turn it back on, test & heal is the only thing I've found that works to bring the node out of the "dead" state immediately.
Let me know if I can give any more info to help solve.
hamster
Re: OpenZWave command via curl
Post by hamster » Monday 23 July 2018 4:56
After posting I was able to figure it out. I'll leave it here for anyone searching later.
In domoticz/www/ozwcp/cp.js you can find all the functions. I ended up doing:
curl -d "fun=test&num=9&cnt=1" -X POST http://192.168.2.240:8080/ozwcp/thpost.html
for reviving the node after i power on the device and
curl -d "fun=refreshnode&node=9" -X POST http://192.168.2.240:8080/ozwcp/admpost.html
for refreshing the node after powering it off, so ozw will mark it dead again and not attempt to route through it.
