Controlicz Alternative (Node red + ifttt) -Google Home
Alexa, Google Home and Siri
pabloalcantara
Post by pabloalcantara » Friday 20 July 2018 4:23
Since Controliz is now a paid subscription, i decided to take onother route and create my simple alternartive version, that is in no way is up to par with Controliz but it is working pretty well for what I need.
So I have created an flow on node red and is using ifttt as the integration with google home.
For this to work you´ll need:
1) Expose node red on public web, and if your IPs is dynamic, an Dynamic DNS (please, read this for security reasons: https://github.com/node-red/cookbook.no ... e-Internet)
2) Create 2 applets on ifttt
2.1) Google Assistant --> Voice command "Turn on $" and "OK" as response --> Web Hook --> url: "https://<<your public ip/name/dynamic dns>>/ghome?cmd=on&device={{TextField}}"
2.2) Google Assistant --> Voice command "Turn off $" and "OK" as response --> Web Hook --> url: "https://<<your public ip/name/dynamic dns>>/ghome?cmd=off&device={{TextField}}"
3) Add this to node red pallet: node-red-contrib-filter, node-red-contrib-splitter and node-red-contrib-google-home-notify
3) Import the flow attached
4) Adjust as desired the variable on the node "Flow Variables":
4.1) domoticzServer: IP/hostame of the Domoticz Server
4.2) domoticzPort: Web port of the Domoticz Server
4.3) domoticzLogin: A user in Domoticz
4.4) domoticzPassword: Password for the user above
4.5) voiceOnCmd: Frase to say when Turning on the device <Ex: Turning on ...., Ligando ...>
4.6) voiceOffCmd: Frase to say when Turning off the device <Ex: Turning off ...., Ligando ...>
4.7) voiceDeviceBegin: Frase to say on the beggining when the device is not recognized <Ex: Device ..... 'voiceDeviceEnd'>
4.8) voiceDeviceEnd: Frase to say on the end when the device is not recognized <Ex: 'voiceDeviceBegin' ..... Not Recognized>
5) Edit the node "domoticz/in" and adjust your ip of your mqtt server
6) Edit the node "Google Home Notify" and use the IP address of your Google Home
7) Now edit each device on Domoticz and on Description use something like this:
;ghome:<word 1>,<word 2>,<word 3>,....,<word 99>; (Do no use spaces between commas)
ex: Kithchen Light --> ;ghome:kitchen;
My bedroom Light --> ;ghome:my bedroom,my room;
Garden Light --> ;ghome:Garden Lights;
Rules:
7.1) Do not use the same word one more than one device
Ex: My bedroom Light --> ;ghome:bedroom,my room,my bedroom;
Chliderns bedroom Light --> ;ghome:Chliderns bedroom;
In the case above, the word bedroom appear on both devices, so if you say "Hey google, Turn on Bedroom", It will turn on the two lights, Because "bedroom" exists on "Chliderns bedroom";
7.2) Always try to use specific words to describe the device, so in the case above, the right way is:
Ex: My bedroom Light --> ;ghome:my room,my bedroom;
So, this is the alfa Version 0.00000000001. Bugs will appear, probably a lot of them...
Help is apreciated.
To do list:
1) Add secutity to the call between ifttt and node red url webhook;
2) Better word detection
3) Better Google Home integration without the need of ifttt
4) ????????? Help....
Sorry for my bad english, I´m Brazilian
Import this on node red
[{"id":"c912b393.34004","type":"tab","label":"Domoticz Google Home","disabled":false,"info":""},{"id":"9bce9ee0.0ac6b","type":"http response","z":"c912b393.34004","name":"","statusCode":"","headers":{},"x":630,"y":480,"wires":[]},{"id":"21aef424.ca2ffc","type":"http in","z":"c912b393.34004","name":"","url":"/ghome","method":"get","upload":false,"swaggerDoc":"","x":150,"y":540,"wires":[["b85f0027.ba98e","c4d8dfb4.10fb7"]]},{"id":"b85f0027.ba98e","type":"template","z":"c912b393.34004","name":"Simple response","field":"payload","fieldType":"msg","format":"html","syntax":"plain","template":"Ok","x":430,"y":480,"wires":[["9bce9ee0.0ac6b"]]},{"id":"c4d8dfb4.10fb7","type":"function","z":"c912b393.34004","name":"Read Dictionare","func":"var cmd = msg.payload.cmd\ncmd = cmd.toLowerCase();\nvar device = msg.payload.device;\ndevice = device.toLowerCase();\nwords = flow.get('words');\nvar idx = 0;\nvar voicecmd;\nif (cmd === \"on\")\n{\n    cmd = 1;\n    voicecmd = flow.get('voiceOnCmd');\n}\nelse if (cmd === \"off\")\n{\n    cmd = 0;\n    voicecmd = flow.get('voiceOffCmd');\n}\nif (cmd === 1 || cmd === 0 )\n{\n    for (i = 0; i < words.length; i++)\n    {\n        var word = words[i].split(\":\");\n        if (device.indexOf(word[0]) > -1)\n        {\n            idx = word[1];\n            name = word[2];\n        }\n    }\n    if (idx !== 0)\n    {\n        msg.payload = '{\"idx\":' + idx + ',\"nvalue\":' + cmd + ',\"svalue\":\"\"}';\n        var msg2 = { payload:\"\" };\n        msg2.payload = voicecmd + \" \" + name;\n        return [ msg, msg2];\n    }\n    else\n    {\n        msg.payload = flow.get('voiceDeviceBegin') + ' ' + device + ' ' + flow.get('voiceDeviceEnd');\n        return [ null, msg];\n    }\n}","outputs":2,"noerr":0,"x":420,"y":600,"wires":[["3d00d6b6.3cb84a"],["26102169.1fc89e"]]},{"id":"3d00d6b6.3cb84a","type":"mqtt out","z":"c912b393.34004","name":"","topic":"domoticz/in","qos":"0","retain":"false","broker":"f52a5e5a.a2be4","x":650,"y":560,"wires":[]},{"id":"4e5aa7a5.f6e1e8","type":"inject","z":"c912b393.34004","name":"","topic":"","payload":"","payloadType":"date","repeat":"600","crontab":"","once":true,"onceDelay":"1","x":130,"y":160,"wires":[["ea87fd01.125c3"]]},{"id":"ee4d95a4.da2a08","type":"change","z":"c912b393.34004","name":"","rules":[{"t":"delete","p":"responseUrl","pt":"msg"},{"t":"delete","p":"headers","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":160,"wires":[["84c00300.5edff"]]},{"id":"84c00300.5edff","type":"splitter","z":"c912b393.34004","name":"","property":"payload.result","x":890,"y":160,"wires":[["6c0c3262.814a3c"]]},{"id":"6c0c3262.814a3c","type":"filter","z":"c912b393.34004","name":"","property":"payload.Description","propertyType":"msg","asArray":false,"itemProperty":"payload","itemPropertyType":"item","rules":[{"t":"cont","v":"ghome:","vt":"str","output":1}],"checkall":"true","outputs":1,"x":1010,"y":160,"wires":[["cf4a4597.950788"]]},{"id":"cf4a4597.950788","type":"change","z":"c912b393.34004","name":"","rules":[{"t":"delete","p":"payload_unsplit","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":300,"wires":[["358aace.3cd7654"]]},{"id":"358aace.3cd7654","type":"function","z":"c912b393.34004","name":"Idx to word","func":"var description = msg.payload.Description;\nvar ghome;\nvar words = new Array();\ndescription = description.split(\";\");\nfor (i = 0; i < description.length; i++) \n{ \n    var option = description[i];\n    if (option.indexOf('ghome') > -1)\n    {\n        msg.idx = msg.payload.idx;\n        msg.name = msg.payload.Name;\n        option = option.split(\":\");\n        ghome = option[1]\n        ghome = ghome.split(\",\");\n        for (j = 0; j< ghome.length; j++)\n        {\n            var line = ghome[j] + \":\" + msg.idx + \":\" + msg.name;\n            line = line.toLowerCase();\n            words.push(line);\n        }\n        msg.words = words;\n        msg.ghome = ghome;\n        return msg;\n    }\n}","outputs":1,"noerr":0,"x":470,"y":300,"wires":[["477f2b7c.41f184"]]},{"id":"477f2b7c.41f184","type":"join","z":"c912b393.34004","name":"","mode":"custom","build":"string","property":"words","propertyType":"msg","key":"idx","joiner":",","joinerType":"str","accumulate":false,"timeout":"10","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":630,"y":300,"wires":[["da510cfa.33f45"]]},{"id":"da510cfa.33f45","type":"function","z":"c912b393.34004","name":"Create Dictionare","func":"words = msg.words\nwords = words.split(\",\");\nflow.set('words',words);\nreturn msg;","outputs":1,"noerr":0,"x":790,"y":300,"wires":[[]]},{"id":"26102169.1fc89e","type":"googlehome-notify","z":"c912b393.34004","server":"a47505a0.d18cb8","name":"","x":680,"y":640,"wires":[]},{"id":"ea87fd01.125c3","type":"change","z":"c912b393.34004","name":"Flow Variables","rules":[{"t":"set","p":"domoticzServer","pt":"flow","to":"localhost","tot":"str"},{"t":"set","p":"domoticzPort","pt":"flow","to":"80","tot":"num"},{"t":"set","p":"domoticzLogin","pt":"flow","to":"","tot":"str"},{"t":"set","p":"domoticzPassword","pt":"flow","to":"","tot":"str"},{"t":"set","p":"voiceOnCmd","pt":"flow","to":"Turning On","tot":"str"},{"t":"set","p":"voiceOffCmd","pt":"flow","to":"Turning Off","tot":"str"},{"t":"set","p":"voiceDeviceBegin","pt":"flow","to":"device","tot":"str"},{"t":"set","p":"voiceDeviceEnd","pt":"flow","to":"not recognized","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":40,"wires":[["c5398e08.fafe6"]]},{"id":"668e7ea1.4792f","type":"http request","z":"c912b393.34004","name":"","method":"GET","ret":"obj","url":"","tls":"","x":550,"y":160,"wires":[["ee4d95a4.da2a08"]]},{"id":"c5398e08.fafe6","type":"function","z":"c912b393.34004","name":"url create","func":"domoticzLogin = flow.get('domoticzLogin');\ndomoticzPassword = flow.get('domoticzPassword');\ndomoticzServer = flow.get('domoticzServer');\ndomoticzPort = flow.get('domoticzPort');\nif (domoticzLogin === '' || domoticzPassword === '')\n{\n    msg.url = 'http://' + domoticzServer + ':' + domoticzPort + '/json.htm?type=devices&filter=light&used=true';\n}\nelse\n{\n    msg.url = 'http://' + domoticzLogin + ':' + domoticzPassword + '@' + domoticzServer + ':' + domoticzPort + '/json.htm?type=devices&filter=light&used=true';\n}\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":160,"wires":[["668e7ea1.4792f"]]},{"id":"f52a5e5a.a2be4","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"30","cleansession":true,"birthTopic":"/nodered/connected","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"/nodered/disconnected","willQos":"0","willPayload":""},{"id":"a47505a0.d18cb8","type":"googlehome-config-node","z":"","ipaddress":"192.168.25.171","language":"pt"}]
Last edited by pabloalcantara on Friday 20 July 2018 12:58, edited 1 time in total.
Wob76
Re: Controlicz Alternative (Node red + ifttt) -Google Home
Post by Wob76 » Friday 20 July 2018 5:51
Thanks for sharing, I also needed to install node-red-contrib-splitter.
I have tested it yet, but I will have a play.
I also might dust off my old solution, it was a variation of one in this thread (viewtopic.php?f=69&t=13607&start=20#p150149).
The limitation I didn't like at the time was it would stop any music playing to talk back, looks like node-red-contrib-google-home-notify has the same limitation as node-red-contrib-chromecast that I was using.
pabloalcantara
Post by pabloalcantara » Friday 20 July 2018 10:55
Thanks,
I"ll take a look on what have you done and see if I can make mine some adjust
EdwinK
Target OS: Raspberry Pi
Post by EdwinK » Friday 20 July 2018 16:08
I don't understand a word of it. So I better wait till you have at least gone to a beta version 1 or so :)
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
pabloalcantara
Post by pabloalcantara » Friday 20 July 2018 16:14
I can help, Whats part do you have trouble?
You already works with ifttt and nodered?
EdwinK
Post by EdwinK » Friday 20 July 2018 16:36
Nope, so that is the problem ;). At the moment I don't really have much time to all this ;) Thanks anyway
jvdz
Domoticz version: Stable
Post by jvdz » Friday 20 July 2018 17:07
This is indeed an interesting approach and fully understand that this needs a more elaborate setup/config description for people starting with MQTT/Node-Red/IFTTT as it does take some effort to install it all correctly.
The basics work quite nicely though so really nicely done!
Thanks for sharing,
Jos
pabloalcantara
Post by pabloalcantara » Friday 20 July 2018 17:44
Thanks @jvdz
If you have any suggestions, fell free to say.
Thanks for sharing,
Jos
jvdz
Post by jvdz » Sunday 22 July 2018 23:01
Thanks @jvdz
I have this already running with 3 IFTTT applets:
  • switch $ On -or- change $ On -or- Open $
  • switch $ Off -or- change $ Off -or- Close $
  • Set $ level # -or- Change $ level #
which sends the text to a single Text Sensor with the "Make a Web request" option:
  • IFTTT:{{TextField}}!on
  • IFTTT:{{TextField}}!off
  • IFTTT:{{TextField}}!{{NumberField}}
A lua event script is fired when the text sensor changes in which I've defined the logic for acting upon the receive Device/Action command.
This allowed me to use Regex like logic to cope with variations on the receive text.
I then use a NodeRed process, which monitors another domoticz text sensor, to cast text of the sensor to the Google Home stating whether the command was executed or states it doesn't understand the Devices/Action.
Your solution makes it easier to implement on the existing devices without a lot of programming, ones you've overcome the initial hurdle of going through the implementation steps.
So no real suggestion at this moment other than maybe at some point put this into a Wiki in
Jos
curious
Post by curious » Wednesday 25 July 2018 22:21
I now use IFTTT with google assist and webhook.
Why is it better to use it with node red ? Is it for the ease of adding devices ?
My apoligies for my bad english too :)
pabloalcantara
Post by pabloalcantara » Wednesday 25 July 2018 22:27
Yes, you com use only Two Applets on iftth e then just adjust the description on your switch on domoticz. Way easier and simples.
The node Red you can create just on time and forget it, and just use domoticz
dswinton
Post by dswinton » Sunday 12 August 2018 15:07
Hi Guys,
I've put together a script that might be an easier solution for this if you're interested:
https://github.com/dswinton/domo-ifttt
Cheers
Users browsing this forum: No registered users and 3 guests
