Since upgrade to v4.9700 selector switch not working (scripts not executed)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
wlevels
Target OS: Raspberry Pi
Domoticz version: V4.9700
Post by wlevels » Thursday 19 July 2018 8:28
Version: v4.9700
Platform: Raspberry Pi
Plugin/Hardware: N/A
Description:
I have a Sonos integration. I control Sonos through running a couple of scripts which are configured in a Selector Switch.
Since the upgrade to v4.9700 (coming from v3.8153) my Selector Switch doesn't work anymore.
When logging in on the Raspberry with the pi user I can just execute the scripts succesfully, but it seems like making a selection on the Selector Switch just doesn't trigger any of the actions configured as follows:
Can anybody advise me how to debug triggering any of the selections to see why the scripts don't run?
Bytheway the scripts have execute permissions for everyone
Wesley
Damsee
Domoticz version: 4.9700
Re: Since upgrade to v4.9700 selector switch not working (scripts not executed)
Post by Damsee » Thursday 19 July 2018 10:26
Had the same issue after the upgrade to 4.9700. It seems the upgrade process encoded specific characters to hexa and you should change it :
=> Replace %3A with : as it worked for me.
Hope that helps ;)
RPI3 Raspbian Stretch + Domoticz v4.9700 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
wlevels
Post by wlevels » Thursday 19 July 2018 10:50
Hope that helps ;)
Hi Damsee, thanks for your reply. Tried that already but after I save it and I reopen my Switch properties it's reverted back to the %3A :(
Damsee
Post by Damsee » Thursday 19 July 2018 11:36
Did you try to restart Domoticz before/after the change ?
My different switchs have semi colon " : " as plain text in my config which is working...
jpham
Post by jpham » Saturday 22 September 2018 13:32
Description:
I did a clean install of Domoticz v4.9700 on Raspberry Pi Stretch. At first i had the same problems with the '%3A'. Did an ./updatebeta, after a restart the '%3A' was gone. But then my second problem, the selector switch only executes the first selected script, see log. I had no problems with older versions 3.xxxxx.
Can anybody advise me?
Checked:
- permisions of all files (755)
- owner of all files (pi)
- selector switch scripts
Domoticz log:
- action clicked on the 'Vol+' button, the script executes
2018-09-22 11:05:59.046 (DummyHardware) Light/Switch (HEOS - Menu)
2018-09-22 11:05:59.035 Status: User: Admin initiated a switch command (170/HEOS - Menu/Set Level)
2018-09-22 11:05:59.282 Status: Executing script: /home/pi/domoticz/scripts/bash/HEOSbyDenon/volume_up.sh
- action clicked on the 'Vol-' button, the script not executed
2018-09-22 11:06:03.073 (DummyHardware) Light/Switch (HEOS - Menu)
2018-09-22 11:06:03.067 Status: User: Admin initiated a switch command (170/HEOS - Menu/Set Level)
2018-09-22 11:06:06.046 (DummyHardware) Light/Switch (HEOS - Menu)
2018-09-22 11:06:06.035 Status: User: Admin initiated a switch command (170/HEOS - Menu/Set Level)
- action clicked on a button, the script not executed
2018-09-22 11:06:22.772 (DummyHardware) Light/Switch (HEOS - Station)
2018-09-22 11:06:22.760 Status: User: Admin initiated a switch command (182/HEOS - Station/Set Level)
- action clicked on abutton, the script not executed
2018-09-22 11:06:26.765 (DummyHardware) Light/Switch (HEOS - Station)
2018-09-22 11:06:26.755 Status: User: Admin initiated a switch command (182/HEOS - Station/Set Level)
paegan
Post by paegan » Saturday 10 November 2018 15:21
Also had issues with scripts not executing after v4.97 update.
After lot of trial and error i discovered that the event system was turned off after this update.
So if that is in the update, or that it is an error in the update process, i don't know.
Fact is, that i turned it on, in " other" settings and everything worked fine.
Hope this helps anyone with the same issue.
