Google assistant - Commands are lower case
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
ayasystems
Target OS: Raspberry Pi
Post by ayasystems » Friday 13 July 2018 9:41
Version: 4.9763
Platform: Raspberry
Description:
I'm creating task on IFTTT in order to do actions with google assistant on my Domoticz
I've a problem due commands are case sensitive. Could be it change to respond with no case sensitive commands?
Example
As action we can create a webhoock with http://domoticz.testweb.com/json.htm?ty ... switchcmd= {{TextField}}
{{TextField}} is the command received by google assistan but it is lowcase and domoticz is not doing the command.
Example, you send on command
http://domoticz.xxxxxxxxxx.com/json.htm ... itchcmd=on
2018-07-13 09:40:09.886 Status: User: admin initiated a switch command (17/Depuradora/on)
"message" : "Error sending switch command, check device/hardware !",
"status" : "ERROR",
"title" : "SwitchLight"
but if you send On... works fine!
http://domoticz.xxxxxxxxxx.com/json.htm ... itchcmd=On
Regards!
juanjogarciac
Re: Google assistant - Commands are lower case
Post by juanjogarciac » Thursday 26 July 2018 19:07
+1
