Fibaro universal binary input relays responds slow
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
BartSr
Target OS: Raspberry Pi
Post by BartSr » Thursday 12 July 2018 10:12
Hi!
I have a few fibaro binary sensors. If I activate an input than immediately the output responds. In Domoticz it takes a long (not set) delay before the status change is shown. Anyone who has a suggestion? I understand it must be possible to immediately see new status and use that accordingly for controlling e.g. other equipment.
KR
-Bart
Re: Fibaro universal binary input relays responds slow
Post by waaren » Thursday 12 July 2018 10:16
Hi!
KR
-Bart
Did you check the delay of the status change in domoticz ? What I see is that the status change is more or less immediate in domoticz but that this is not instantly reflected in the GUI.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
BartSr
Post by BartSr » Thursday 12 July 2018 11:34
Hi Waaren,
Thanks for yr reply.
I did not set any
"delay of the status change" in domoticz
Will there probably be a more or less hided setting?
Or are you referring to the fibaro hardware settings? These are all set to 0.
Do I overlook probably something?
KR
-Bart
Post by waaren » Thursday 12 July 2018 16:02
What I mean with "What I see is that the status change is more or less immediate in domoticz" is that any script based on the device-changed event is started immediate and I also see these changes in the domoticz logfile the moment they occur.
leonardlopes
Post by leonardlopes » Tuesday 18 September 2018 17:31
It’s possible to add Z-Wave output to most devices but that depends on the available outputs the device provides.
If the device has some dry contact outputs then you can use a Fibaro Universal Sensor or a Fibaro Door & Window Sensor.
If you are dealing with 240V then a Fibaro Relay or a Qubino Relay would be a better alternative.
_______________________
cleanmaster https://facebooklite.vip/ https://mathway.vip/
Users browsing this forum: No registered users and 4 guests
