/mnt/1wire
Pieter
Target OS: Raspberry Pi
Domoticz version: 4.9700
/mnt/1wire
Post by Pieter » Wednesday 11 July 2018 23:43
Ds18b20 - Tempsensor.png (31.95 KiB) Viewed 94 times
I really do not understand this. How do I address this?
Regards,
Pieter
Als het niet kan zoals het moet, dan moet het maar zoals het kan.
Pieter
Re: /mnt/1wire
Post by Pieter » Thursday 12 July 2018 0:05
# This works sometimes on my other Raspberry.
import os
import os.path
import glob
import time
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
# root/sys/bus/devices/28-0517a23d79ff
# file=w1_slave
base_dir = '/sys/bus/w1/devices/'
# device_folder = glob.glob(base_dir + '28*')[0]
device_folder = glob.glob(base_dir + '28-0517a23d79ff')[0]
device_file = device_folder + '/w1_slave'
def read_temp_raw():
f = open(device_file, 'r')
lines = f.readlines()
f.close()
return lines
def read_temp(scale):
lines = read_temp_raw()
while lines[0].strip()[-3:]!='YES':
# time.sleep(0.2)
equals_pos = lines[1].find('t=')
if equals_pos != -1:
temp_string = lines[1][equals_pos+2:]
temp_c = float(temp_string) / 1000.0
temp_f = temp_c * 9.0 / 5.0 + 32.0
if scale == "F":
return "{:.1f}".format(temp_f)
if scale =="C":
return "{:.1f}".format(temp_c)
else:
return temp_c, temp_f
while True:
if os.access(device_file, os.R_OK):
filedata=read_temp("C")
print (filedata.replace('.', ','))
# time.sleep(1)
else:
print("De file:\n\n"+device_file+"\n\nof de directory:\n"+device_folder+"\n\nbestaat ineens niet meer ;-)")
time.sleep(0.5)
# break
Regards,
Pieter
gordonb3
Domoticz version: Custom
Re: /mnt/1wire
Post by gordonb3 » Thursday 12 July 2018 20:17
Not quite getting the purpose and/or question meant with this topic.
I did however see your other post today and you might want to make a note that we're not Microsoft Support calling from Ivory Coast with an Indian accent, so we can't actually look onto your system to figure out ourselves what your problem might be.
