Plugin system not working with upgrade database
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Hesmink
Target OS: Raspberry Pi
Post by Hesmink » Wednesday 11 July 2018 19:20
Hello all,
I recently upgraded to the latest stable.
Since the upgrade the plugin system no longer works for me.
Something in the upgrade database is preventing it to start up. With the default database, the plugin systems works:
With default database:
2018-07-11 18:58:11.240 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-07-11 18:58:11.247 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-07-11 18:58:11.254 Status: Startup Path: /home/pi/domoticz/
2018-07-11 18:58:11.842 Status: PluginSystem: Started, Python version '3.5.3'.
2018-07-11 18:58:11.870 Status: WebServer(HTTP) started on address: :: with port 8080
2018-07-11 18:58:11.926 Status: WebServer(SSL) started on address: :: with port 443
2018-07-11 18:58:11.928 Status: Proxymanager started.
2018-07-11 18:58:11.929 Status: TCPServer: shared server started...
2018-07-11 18:58:11.929 Status: RxQueue: queue worker started...
2018-07-11 18:58:13.930 Status: EventSystem: reset all events...
2018-07-11 18:58:13.932 Status: EventSystem: reset all device statuses...
2018-07-11 18:58:13.996 Status: PluginSystem: Entering work loop.
2018-07-11 18:58:14.072 Status: Python EventSystem: Initalizing event module.
2018-07-11 18:58:14.073 Status: EventSystem: Started
2018-07-11 18:58:14.073 Status: EventSystem: Queue thread started...
With upgrade database:
2018-07-11 19:07:43.449 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-07-11 19:07:43.450 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-07-11 19:07:43.451 Status: Startup Path: /home/pi/domoticz/
2018-07-11 19:07:43.499 Status: EventSystem: reset all events...
2018-07-11 19:07:43.513 Status: WebServer(HTTP) started on address: :: with port 8080
2018-07-11 19:07:43.525 Status: WebServer(SSL) started on address: :: with port 443
2018-07-11 19:07:43.527 Status: Proxymanager started.
2018-07-11 19:07:43.528 Status: Camera: settings (re)loaded
2018-07-11 19:07:43.597 Status: TCPServer: shared server started...
2018-07-11 19:07:43.597 Status: RxQueue: queue worker started...
2018-07-11 19:07:45.598 Status: Hardware Monitor: Started
2018-07-11 19:07:45.612 Status: Pinger: Started
2018-07-11 19:07:45.612 Status: Wunderground: Worker started...
2018-07-11 19:07:45.612 Status: WOL: Started
2018-07-11 19:07:45.613 Status: DarkSky: Started...
2018-07-11 19:07:45.814 Status: RFLink: Using serial port: /dev/ttyUSB0
So no mention of the plugin system.
Any idea what Domoticz checks in the database that can prevent startup of the plugin system?
Users browsing this forum: kmccor and 1 guest
