Problem with selector with buttons
Moderators: robgeerts, htilburgs
bregelius
Post by bregelius » Wednesday 11 July 2018 13:02
Hi everybody,
i have a problem when trying to add a switch which has a button set or a selection menu with buttons. When i place a dimmer there is no problem, but if i change the switch to a "selector" i obtain at dashticz a text string instead of the buttons. For example, in the attached image , that switch is a selector with buttons (OFF, Low, Medium, High) and what i`m obtaining at dashticz is a text string, only one... I have been searching a lot in the forum, but i didn`t find a similar problem. Can anybody can help me? I have attached two pictures (one with dashticz's problem and one with original switch as shown and fully working with domoticz)
Thnx in advance :)
Switch as shown at domoticz
Switch as shown at dashticz
HansieNL
Target OS: Raspberry Pi
Re: Problem with selector with buttons
Post by HansieNL » Thursday 12 July 2018 22:28
Can you clean your browser cache and try latest Dashticz beta?
Problem should then be solved.
Blah blah blah
bregelius
Post by bregelius » Monday 16 July 2018 18:44
Thank you for your answer... i have tried that solution, with different browsers even a different computer (i’m using domoticz for windows) and still no solution.....
felix63
Domoticz version: 3.8275
Post by felix63 » Monday 16 July 2018 21:35
I have the same problem occurring. But I don't think the problem is specific to Dashticz. The same thing happens when looking at the switches in Domotix or Pilot on my iPhone . Only the Domoticz app shows the selector switches correct. Also see viewtopic.php?f=6&t=24181
So probably something is changed in how the values are passed on and the Dashticz/Domotix/Pilot need to be updated.
bregelius
Post by bregelius » Tuesday 17 July 2018 9:51
I think you are right.... after reading your comment, i downgraded to a previous version of domoticz (in other computer which is not running the domo server) and BINGO, buttons appeared in Dashticz where before i had a text string.... so it seems to be a "problem" of Domoticz as you said.
Lorr
Post by Lorr » Saturday 21 July 2018 11:54
I have the exact same problem. Been searching for hours on the forum! Will try to change to an other version of Domoticz...
Ectholian
Post by Ectholian » Wednesday 01 August 2018 19:50
This is due to a change in the domoticz api. See my previous post about it:
http://www.domoticz.com/forum/viewtopic ... 04#p187204
Ierlandfan
Post by Ierlandfan » Tuesday 21 August 2018 13:32
I just changed js/version.js
from
var levelNamesEncodeVersion = '3.9476'; /* Domoticz version above this, level names are encoded *
To:
var levelNamesEncodeVersion = '3.7476'; /* Domoticz version above this, level names are encoded *
and it worked. 3.7.476 is arbitrary. It only has to be lower as your current version of Domoticz.
I was running Domoticz version 3.9464 so it seems that the versioning was a little off.
honselbonsel
Post by honselbonsel » Tuesday 30 October 2018 9:26
Hi Ierlandfan,
i was searching for the named fiel in the dashticz folder and couldn´t find the line to change.
Were is the file located? and where should be normally the line be?
thank You :-)
br
jens
honselbonsel
Post by honselbonsel » Tuesday 30 October 2018 14:18
ok,
i´ve found the Solution.
As the api sends base64 encoded string this must be decoded in dashticz.
viewtopic.php?f=67&t=17427&start=380
Lokonli
Post by Lokonli » Tuesday 30 October 2018 14:43
ok,
Which Domoticz version do you use?
