Concatenating an URL with values from sensors. Topic is solved
radiochild
Post by radiochild » Wednesday 11 July 2018 7:32
Hi, I am running Domoticzs on a Synology NAS and I am trying to send a value to an ESPEasy LED display. I can send the dummy info, just as a straight number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..333 }
but I can't substitute a sensor value for the number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..sensortemp}
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..['Sensor_Temperature']}
The errors usually relate to concatenation a global or things like that.
I don't understand the examples and other posts I have read. Can someone please explain if this can work or how to do it if it can't?
Target OS: Raspberry Pi
Re: Concatenating an URL with values from sensors.
Post by waaren » Wednesday 11 July 2018 9:33
Yes it can work. If you post the complete script it is easier to comment on what modifications are needed to get this to work.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
radiochild
Post by radiochild » Wednesday 11 July 2018 12:13
Hi Waaren, thanks for having a look for me.
-- Variables
baseurlESPEasy = "http://192.168.1.xx/control?cmd="
commandArray =  {}
if devicechanged['Undercot_Temperature'] then
This works.
I just can't figure out how to put a value from a sensor where the '333' is.
Post by waaren » Wednesday 11 July 2018 12:56
-- Variables
commandArray =  {}
This works.
This will send the same as in your example with the temperature from sensor Undercot_Temperature. (dzVents)
-- Send Undercot Temp
    on =        {       devices   =   { "Undercot_Temperature" }},
    logging =   {       level   =   domoticz.LOG_DEBUG,
                        marker  =   "Send undercot" },
    execute = function(domoticz, undercot )
        local baseurlESPEasy = "http://192.168.1.xx/control?cmd="
        domoticz.openURL({
                            url = baseurlESPEasy .. "7dt" .. undercot.temperature,
                            method = "GET"
radiochild
Post by radiochild » Wednesday 11 July 2018 13:29
Hi Waaren.
I tried your code and I get;
Error: EventSystem: in Portable LED Display: [string "-- Send Undercot Temp ..."]:6: attempt to index global 'domoticz' (a nil value)
I am using this in Events. I realise I didn't mention that before, does that make a difference?
jvdz
Domoticz version: Stable
Post by jvdz » Wednesday 11 July 2018 13:37
So you have an LUA event script and you want to send the new received value for ... to ESPEASY....right?
Something like this should be close for a Device Lua event script:
commandArray =  {}
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'.. devicechanged['Undercot_Temperature']}
.. but are you sure about that ESPEASY URL? Does that work directly from a browser?
Jos
radiochild
Post by radiochild » Wednesday 11 July 2018 13:46
Hi jvdz,
Thank you! That worked a charm. The url works in a browser for ESPEasy. It now works in Domoticz. It's just an update to a MAX7219 LED display. So simple but I just couldn't figureit out.
Thank you again, Waaren and jvdz for helping me out.
Post by waaren » Wednesday 11 July 2018 17:19
Hi Waaren.
Hi radioChild, my script is dzVents. Choose dzVents in the event editor and copy paste the script ..
Users browsing this forum: Bing [Bot] and 3 guests
