Nefit Easy Domoticz: XMPP authentication failure
askmurphy
Target OS: Raspberry Pi
Post by askmurphy » Wednesday 11 July 2018 0:48
Hello !
I had Nefit Easy running on Domoticz for a long time, no problem.
We got a new modem, now everything works nice but the Nefit Easy connection doesn't work anymore.
When I enter our Nefit details (changed below with fake) and runs the command:
sudo easy --serial=2352552556 --access-key=jdjsAJDfakeFHDDWQ --password=Secret234r2 status
I get this:
When I use the Nefit Easy app on my iphone with WIFI: it works.
How can I fix this ?
Thanks in advance !
;-) Arthur
felix63
Domoticz version: 3.8275
Re: Nefit Easy Domoticz: XMPP authentication failure
Post by felix63 » Friday 13 July 2018 15:38
Hi Arthur,
I came across a similar problem a while a go. Found a solution in viewtopic.php?t=23638 . Did you try that?
Regards,
Lex
askmurphy
Post by askmurphy » Saturday 14 July 2018 12:48
Checked it all, my sollution was to uninstall all nefit-stuff and nefit folders and files.
Also removed node and installed the lastest node. After that: //gitgub/robertklep/nefit-easy-cli and -/nefit-easy-http-server
Runs again !
