lua scripts not fired up
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
DonLeo
Target OS: Raspberry Pi
Domoticz version: V4.9700
Post by DonLeo » Tuesday 10 July 2018 22:59
Hi there,
'Suddenly' if I change something in the setup, doesn't matter what, and I save the database my lua scripts are not fired up anymore, the Event system seems to be stopped. I have to load a previous version of domoticz.db to fire up the lua scripts again and are loosing report information.
Can someone tell me how I can check / restart the event system? or maybey my database is corrupt or...
Thxs, DonLeo
Version: 4.9700
Platform: Pi 2 with Strech Debian
Hardware: Aeon Zwave and self made RF link
Raspberry Pi II + Image 4834
AeonLabs Z-stick 5
Domoticz Latest version
DonLeo
Re: lua scripts not fired up
Post by DonLeo » Friday 13 July 2018 22:49
Hi all,,
Solved the problem by myself.... I reinstalled from scratch.
Can close this topic
AeonLabs Z-stick 5
Post by waaren » Friday 13 July 2018 22:56
Hi all,,
@DonLeo,
did you find anything in the database or elsewhere in the domoticz environment that could have caused this ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
DonLeo
Post by DonLeo » Tuesday 17 July 2018 22:39
Hi Waaren,
No, I found out, every time I saved the database, the setting of the Event System (LUA/BLOCKY/SCRIPTS) was reset (non active) so thats why there where no events in the log. I couldnt fixe this, so I started from scratch.
DonLeo
AeonLabs Z-stick 5
cardy
Post by cardy » Wednesday 18 July 2018 0:23
Version: 4.7900
Platform: Linux (Fedora 28)
Plugin/Hardware: Linux VM
I have a similar problem to the above my initial issue was the script I have would not run at all.
	logging = {
		level = domoticz.LOG_FORCE, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
		marker = "TEST"
	active = true,
	    devices = {
	        581
	execute = function(domoticz, mydevice)
	    domoticz.notify('Well it ran!', domoticz.PRIORITY_NORMAL)
		domoticz.log('Device ' .. mydevice.name .. ' was changed', domoticz.LOG_FORCE)
		if (mydevice.state == 'On') then
			domoticz.notify('Hey!', 'I am on!', domoticz.PRIORITY_NORMAL)
		if (mydevice.state == 'Off'
		) then
			domoticz.notify('Hey!', 'I am off!', domoticz.PRIORITY_NORMAL)
I have enabled debug to level 5 and there were no errors.
Eventually I did the following after seeing comments about the switch for dzVents not working in other places.
  • Stop domoticz
  • Backup the database then use sqlite3 to access the database
  • Run the following SQL: UPDATE Preferences SET nValue = 0 WHERE Key = 'DisableDzVentsSystem';
This re-enabled dzVents but I now get the following error:
Error: EventSystem: in /usr/bin/dzVents/runtime/dzVents.lua: cannot open /usr/bin/dzVents/runtime/dzVents.lua: No such file or directory
I don't know why its using /usr/bin
This is my process thats running:
domoticz  4401     1  0 22:56 ?        00:00:06 /usr/bin/domoticz -www 8080 -sslwww 8443 -sslcert /var/lib/domoticz/domoticz.pem -sslpass -sslmethod -ssloptions -ssldhparam -wwwroot /usr/share/domoticz/www -dbase /var/lib/domoticz/domoticz.db -userdata /usr/share/domoticz/ -verbose 1 -log /var/log/domoticz.log -loglevel 5
I did read somewhere that WorkingDirectory should be set in systemd's service file, but in my case this is set.
[Unit]
Description=Domoticz Home Automation Server
[Service]
User=domoticz
Group=domoticz
EnvironmentFile=/etc/sysconfig/domoticz
ExecStart=/usr/bin/domoticz -www $WWW_PORT -sslwww $SSL_PORT -sslcert $SSLCERT -sslpass $SSLPASS -sslmethod $SSLMETHOD -ssloptions $SSLOPTIONS -ssldhparam $SSLDHPARAM -wwwroot $WWW_ROOT -dbase $DBASE -userdata $USERDATA -verbose $VERBOSE -log $LOG -loglevel $LOGLEVEL
WorkingDirectory=/usr/share/domoticz
# Give the right to open priviliged ports. This allows you to run on a port <1024 without root permissions (user/group setting above)
#CapabilityBoundingSet=CAP_NET_BIND_SERVICE
[Install]
WantedBy=multi-user.target
The Settings in /etc/sysconfig/domoticz are:
WWW_PORT=8080
SSL_PORT=8443
SSLCERT="/var/lib/domoticz/domoticz.pem"
SSLPASS=""
SSLMETHOD=""
SSLOPTIONS=""
SSLDHPARAM=""
WWW_ROOT="/usr/share/domoticz/www"
DBASE="/var/lib/domoticz/domoticz.db"
USERDATA="/usr/share/domoticz/"
VERBOSE=1
LOG="/var/log/domoticz.log"
LOGLEVEL="5"
Any ideas why domoticz is using this path would be greatly welcomed I would love to get dzVents working but am a loss as to where this path comes from.
Users browsing this forum: No registered users and 4 guests
